May 02, 2024, 05:57:26 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri N/A 89-94
'91 N/A no start
« previous
next »
Pages: [
1
Print
Author
Topic: '91 N/A no start (Read 5310 times)
ilarson007
Full Member
'91 N/A no start
on:
July 15, 2007, 09:39:00 AM »
It has gas, it has spark, it's in time, and it has compression... any suggestions?
Look closely at the picture.
http://img487.imageshack.us/img487/1724/photoshop2ge6.jpg\\
" target=\\"_blank\\">
W@W
My Cardomain:
http://www.cardomain.com/ride/2502368/1\\
ilarson007
Full Member
'91 N/A no start
Reply #1 on:
July 20, 2007, 04:20:00 AM »
All 4 cylinders have 120lbs. of compression. All are getting spark, and all are getting gas (when we take the plugs out after trying to start it, they are plenty wet). What could be causing this? Has anyone ever had a problem like this?
W@W
My Cardomain:
need4speed428
Sr. Member
'91 N/A no start
Reply #2 on:
July 20, 2007, 11:57:00 AM »
Make sure your timing is on. Sounds like your timing is off.
2007 Toyota Tacoma 4x4
1966 F100
2006 Yamaha FZ1
150bhp at only 439lbs!
Wirebrain
Newbie
'91 N/A no start
Reply #3 on:
July 20, 2007, 06:08:00 PM »
You might try putting a fresh set of plugs in. I ran into a situation once where the plugs were getting Spark to them but the porcelin insolators had carbon tracted and the spark was going straight to ground. Boy was the guy I bought the car from cheap..POed when I changed the plugs and it fired right up....
ilarson007
Full Member
'91 N/A no start
Reply #4 on:
July 21, 2007, 03:56:00 PM »
we timed it before trying to start it and we put it new plugs, so, good ideas but already tried.
W@W
My Cardomain:
Richter12x2
Sr. Member
'91 N/A no start
Reply #5 on:
July 25, 2007, 06:27:00 AM »
Air leak between the MAF and the intake manifold?
ilarson007
Full Member
'91 N/A no start
Reply #6 on:
August 01, 2007, 08:31:00 AM »
But that wouldn't effect starting though, would it? Cause I've started it with out the intake pipe on (it dies almost immediately, but it still starts).
EDIT: P.S. Nice Neon (SRT-4?)
W@W
My Cardomain:
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
'91 N/A no start
Reply #7 on:
August 01, 2007, 09:55:00 AM »
If you still have fuel pressure in the rail you might be able to start it without the VAF, but the fuel pump to my knowledge will not turn on during cranking without the VAF.
ilarson007
Full Member
'91 N/A no start
Reply #8 on:
August 02, 2007, 04:14:00 PM »
well we unplugged the fuel line and we had plenty of gas spewing out during cranking.
W@W
My Cardomain:
hairhook
Newbie
'91 N/A no start
Reply #9 on:
September 03, 2008, 05:19:00 AM »
I had the same problem. Checked the error codes and came up with 01 and 15 which points to ign. and lean fuel problems. Checked everything I could think of, then disconnected the negative side of the battery to power down the computer. Reconnected and the car started and ran fine. Try resetting the computed mod.
D22A
Sr. Member
'91 N/A no start
Reply #10 on:
September 03, 2008, 06:59:00 PM »
check spark plugs meby they are whet,
1996 MT 3000GT LS
1993 CAPRI n/a
Old-Timer
'91 N/A no start
Reply #11 on:
September 03, 2008, 07:17:00 PM »
Hey Guys! You're responding to a year plus old post. Gus.
mkIV
Newbie
'91 N/A no start
Reply #12 on:
October 26, 2010, 06:31:00 AM »
Yes but all these go into the searchable archive which may be helpful to people later.
mcanchola2
Full Member
'91 N/A no start
Reply #13 on:
July 09, 2011, 07:05:00 AM »
thats so true
Print
Pages: [
1
« previous
next »
Capri N/A 89-94
'91 N/A no start
