thanks gus and rocket for the info,i got the short block and it was the small nose crank i had taken the old crank, had it checked and polished and put it in the new engine block beings it was bigger snout,if i find the stuff to change it over i will have a spare when time comes,but i have checked back and checked again with the cams being off but they seemed like they were lined up,i will check again just because it is not that time consuming and i could have missed something hell you never know i'm not perfect i'm human,mistakes happen.will let you know outcome.
