Author Topic: How to change out Front Axles?  (Read 5170 times)
Zombieblowup
    • 1991 Mercury Capri N/A
« on: July 25, 2016, 06:34:59 PM »
I've had my Capri since October of last year and absolutely love this car. I firmly believe it can lay anything in its path to waste.. (with enough Upgrades) I recently dusted a BWM E30. However, in the process of ripping mad burnouts... I broke my Passenger side Axle and proceeded to look stupid in front of ladies.. (and gentlemen) I've tried to take them off when I put a new Clutch in, but failed... So I took out the housing with the axles. (ps. It was a b*tch)
Now, time has come where I must take this axle out. I've tried anything from Pickaxes to Chains to dual sledgehammers, and it has moved about a 1/4 inch. Am I missing something or is it just fubar?
Please Help  :-\
I must continue to live in the fast lane!!!
Re: How to change out Front Axles?
« Reply #1 on: July 25, 2016, 08:13:34 PM »
https://www.youtube.com/watch?v=VxMFKTwe6hA gives a basic idea on how to do it. Also don't do burnouts and stuff in your Capri the transmissions suck and will explode.
« Last Edit: July 25, 2016, 08:19:12 PM by WashiestSnake »
Zombieblowup
« Reply #2 on: July 26, 2016, 03:17:22 PM »
I was wanting more of a step by step tutorial. Does anyone have experience with getting a capri Axle out? This one is stuck. I'd love a written
« Reply #3 on: July 26, 2016, 10:39:07 PM »
That basically is a step by step tutorial theres nothing different that you have do to get it out of a Capri.
« Reply #4 on: July 27, 2016, 09:09:30 AM »
Zombie is referencing removing a stuck axle.  I've had to buy two transmissions due to being unable to remove stuck axles.  Local transmission shops couldn't do any better.
Jack
Zombieblowup
« Reply #5 on: August 01, 2016, 04:13:31 PM »
Jack
How much did you end up paying for one??
Zombieblowup
« Reply #6 on: August 01, 2016, 04:21:27 PM »
im going to try attaching a slide Hammer to some vice-grips and use shock force. I will return with results tomorrow. Wish me luck guys!!
« Reply #7 on: August 01, 2016, 07:56:44 PM »
Luck wished, but please refrain from burnouts in these cars, otherwise youll end up with a dead trans. What I would recommend would be getting a LSD, so that if you do; do a burnout it wont blow your trans to hell.
« Last Edit: August 02, 2016, 06:28:10 PM by WashiestSnake »
« Reply #8 on: August 02, 2016, 09:49:21 AM »
Jack
Here in NC, $400 was the best I could find.  WV $300, and it turned out to be bad.  Really lucked out at one from a Forum member for $100 with only 100K.  It's been in a year now and except for a leak at the shifter rod, it's going great.
Jack
Zombieblowup
« Reply #9 on: August 02, 2016, 05:00:07 PM »
It came out!!! Thanks Guys!!!  :) :)
« Reply #10 on: August 02, 2016, 06:07:37 PM »
Awesome, now your one step closer to being back on the road!
