April 29, 2024, 08:30:58 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri XR-2 89-94
1989 SA turbo no Spark
« previous
next »
Pages: [
1
Print
Author
Topic: 1989 SA turbo no Spark (Read 4136 times)
No1Alexander
Newbie
1989 Ford SA Capri Turbo convertible
on:
March 28, 2019, 04:56:02 AM »
Hi peoples....
I live in NSW Australia and own a 1989 SA Turbo ( engine is a B6T 14 ) Capri which was running fine until one day it just stopped whilst still driving around town . 1st thought was a coil ... replaced coil car ran for 30 seconds or so then stopped since then I have replaces the plug leads distributor cap and rotor also the Ignition pickup module as well as the Igniter and spacer plate ...
all to no avail ... I am at a loss where to look next ...
is there a cam or crank sensor and if so where as I looked up top and down below and couldn't find the bugger
any advise would be greatly appreciated
Regards Alexander
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Re: 1989 SA turbo no Spark
Reply #1 on:
March 28, 2019, 11:14:19 PM »
Yes the crank sensor is in the distributor, in our case it's coupled with the Ignitor which is a common issue. If you search the forums here with "Ignitor" you will find some threads with good info in them
No1Alexander
Newbie
Reply #2 on:
March 29, 2019, 01:55:32 AM »
I have actually replaced all the electronic components in the distributor and still no spark is there a way to test them all or should I now be looking else where ? also my rpm counter does not move when the car is cranking ....
does that mean anything
Regards Alexander
Print
Pages: [
1
« previous
next »
Capri XR-2 89-94
