Author Topic: 1989 SA turbo no Spark  (Read 4133 times)
No1Alexander
    • 1989 Ford SA Capri Turbo convertible
« on: March 28, 2019, 04:56:02 AM »
 Hi peoples....
I live in NSW Australia and own a 1989 SA Turbo ( engine  is a B6T 14 ) Capri which was running fine until one day it just stopped whilst still driving around town . 1st thought was a coil ... replaced coil car ran for 30 seconds or so then stopped since then I have replaces the plug leads distributor cap and rotor also the Ignition pickup module as well as  the Igniter and spacer plate ...
all to no avail ...  I am at a loss where to look next ...
is there a cam or crank sensor and if so where as I looked up top and down below and couldn't find the bugger
any advise would be greatly appreciated
Regards Alexander
Re: 1989 SA turbo no Spark
« Reply #1 on: March 28, 2019, 11:14:19 PM »
Yes the crank sensor is in the distributor, in our case it's coupled with the Ignitor which is a common issue. If you search the forums here with "Ignitor" you will find some threads with good info in them
No1Alexander
« Reply #2 on: March 29, 2019, 01:55:32 AM »
I have actually replaced all the electronic components in the distributor and still no spark is there a way to test them all or should I now be looking else where ? also my rpm counter does not move when the car is cranking ....
does that mean anything ???
Regards Alexander
