Author Topic: Flashing air bag light  (Read 4202 times)
9193CapriXR2
« on: October 11, 2023, 10:08:08 AM »
How do I fix or disable the flashing yellow airbag light??
Re: Flashing air bag light
« Reply #1 on: October 13, 2023, 09:02:08 AM »
The airbag module is a small blue box mounted on the firewall above the steering column. Unplugging it will cause the light to stay on,just remove the bulb.
9193CapriXR2
« Reply #2 on: October 19, 2023, 04:34:43 PM »
So looking at the wiring diagram in ShopKey pro there is a yellow/blak wiring coming from the ABS Diagnostic Module that powers the indiator light in the instrument cluster.  I should be able to just cut this wire to extinguish the light....correct?
« Reply #3 on: October 20, 2023, 10:02:09 AM »
I hadn't looked into that, but sounds like it would work.
