Author Topic: vehicle speed sesor  (Read 8930 times)
fernjohn
vehicle speed sesor
« on: March 28, 2009, 01:43:00 PM »
where is the vehicle speed sensor located on a 1992 capri with  4eat transmission? my tranny is acting up and the code i pulled out of the tranny controller said vehicle speed sensor. any help would be appreciated
vehicle speed sesor
« Reply #1 on: March 28, 2009, 05:52:00 PM »
We have a cable-driven speedometer, there is no VSS.
Although im not sure if there is anything internal in the tranny that tells the controller speed.
vehicle speed sesor
« Reply #2 on: March 28, 2009, 08:15:00 PM »
Hey Fern! Is your trans automatic or manual? Your post is confusing. It sounds like an auto. There is a device called a throttle position sensor but not sure of what you stated.  Gus
itsmeisatu
vehicle speed sesor
« Reply #3 on: March 29, 2009, 01:03:00 AM »
From the 93 EVTM:
"Vehicle speed information is provided by the Pulse Generator located on the transaxle housing.  This component is a magnetic pickup that detects the passing of projections on the transaxle's reverse forward drum.  This drum has 12 projections that are evenly spaced 30 degrees apart.  As the drum rotates, a voltage pulse is generated in the magnetic pickup each time a projection passes the sensor.  The Transmission Control Module determines vehicle speed by counting the times per second that a pulse is generated."
The wiring diagram shows a Turbine Sensor (pulse Generator) with 4 wires- ground,tran fluid temp switch and 2 wires from pickup,  the pickup wires go to terminals 2J & 2L of the trans control
 module.  I'd look for a 4 wire connector coming off the transmission.
George
fernjohn
vehicle speed sesor
« Reply #4 on: March 29, 2009, 03:16:00 AM »
thanks for the info, the tranny is an auto. i will look for a sensor with 4 wires. i saw a couple of sensors in housing and will check those.
bhazard
vehicle speed sesor
« Reply #5 on: March 29, 2009, 12:16:00 PM »
I wonder if such a pickup exists in our manual trannies...?
vehicle speed sesor
« Reply #6 on: March 29, 2009, 04:51:00 PM »
I've had one apart, nope.
