Pages: 1 [2] 3
Author Topic: Cheap springs  (Read 8577 times)
LarryC
Cheap springs
« Reply #15 on: December 15, 2011, 11:59:00 AM »
thank you.  I should have loosen bolt before removing.
Snigalfriz
    • 1991 NA Capri
Cheap springs
« Reply #16 on: December 16, 2011, 02:28:00 PM »
About how long does it take to change the springs?
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
tonlaw71
Cheap springs
« Reply #17 on: December 16, 2011, 03:05:00 PM »
Depends on if you have issues with that nut!   :rolleyes:  Also, a lot of times the bolt that goes thru the rear trailing arm gets rusted into the bushing and that can be a bear, too. Once you get the strut out, compress the spring and everything, you should be done in about an hour. That's my experience, anyway.
///'92 Plasti-Dipped XR2\\\
Snigalfriz
    • 1991 NA Capri
Cheap springs
« Reply #18 on: December 16, 2011, 03:09:00 PM »
An hour per spring?
2003 Lincoln LS
2014 Chevy Cruze LT
tonlaw71
Cheap springs
« Reply #19 on: December 17, 2011, 02:54:00 AM »
Yep...Once you get the hang of it, it could be faster. I really didn't want to rush it after hearing all the horror stories about spring compressors!   :rolleyes:
LarryC
Cheap springs
« Reply #20 on: December 17, 2011, 07:19:00 AM »
Installed the rear 'cheap' springs. Second spring was somewhat easier (to install).  I'm waiting for front pair of struts, which I have order thru Ebay.  These 'cheap' lowering springs only lowered the rear by about 3/4-7/8".  I dont think it was worth the one day of work.  Maybe, when the front is complete or when car is driver more, it might settle lower. thanks again.
Cheap springs
« Reply #21 on: December 17, 2011, 07:25:00 AM »
It will settle a bit with driving, also the drops are advertised from a "factory" stance. The springs you removed were probably not at OEM height to begin with due to normal wear.
Snigalfriz
    • 1991 NA Capri
Cheap springs
« Reply #22 on: December 20, 2011, 05:59:00 PM »
I installed the rear today, and it looks sweet.  Going to do the fronts tomorrow.
I was able to install them without using a spring compressor.
I remove the center nut, and then disconnected the strut from the suspension, after raising to jackstands, and then raised the car until I could get the old springs out. Then put the new springs on reconnected the strut, and slowly lowered the car and aligned the top of the strut with the mount.
Saved a lot of time.
2003 Lincoln LS
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
Cheap springs
« Reply #23 on: December 21, 2011, 07:26:00 PM »
Installed the fronts yesterday, and I like the stance.  I haven't driven it much, but they feel good.
I also found out that these springs are very old inventory and that is why they were so cheap.  The springs are manufactured by BellTech.
2003 Lincoln LS
2014 Chevy Cruze LT
kraversxr2
Cheap springs
« Reply #24 on: December 23, 2011, 12:45:00 AM »
I just popped on a set of these!  Do I need to order shorter struts or can I use OEM?
Cheap springs
« Reply #25 on: December 23, 2011, 06:21:00 AM »
OEM will work, it's not a drastic drop. Also, there is not a "shorter" strut available
kraversxr2
Cheap springs
« Reply #26 on: December 23, 2011, 12:17:00 PM »
Thank You, thats good to know.  Do I need to
get those Camber Bolts?
LarryC
Cheap springs
« Reply #27 on: December 30, 2011, 09:20:00 AM »
I just installed my front 'cheap springs' with new 'KYB' struts.  The 'fronts' were a lot easier (to install)than the rear. I would like to thank previous posts on wheel and tire sizes.  That information was helpful.  I bought a set of 205/40/17, rims & tires from CL for $200.(I had the original 14" alum).  BTW, I had 'popping noise' from front.  Most of the noise has been eliminated by new strut upper mounts.  I am really pleased with the new aggressive look and ride.  thank you
Snigalfriz
    • 1991 NA Capri
Cheap springs
« Reply #28 on: January 02, 2012, 01:17:00 AM »
Just picked up a set of the KYB GR-2 struts.
2003 Lincoln LS
2014 Chevy Cruze LT
mhowell
Cheap springs
« Reply #29 on: January 02, 2012, 09:18:00 AM »
Snigalfriz could you post some before and after pics of you car. Just curious what it looks like lowered.
My Rides
1991 Mercury Capri XR2 (Silver)
1992 Mercury Capri XR2 (Charcoal)
1991 Mercury Capri XR2 (RED)
Pages: 1 [2] 3
