Quote from: 350boatracing on July 16, 2014, 08:50:09 PMHopefully the oil change did it for you. Mine was rattling pretty good on start up then I did an oil change with high mileage oil and it took care of the problem completely.I ran some ATF through it, drove it gently for a few miles, then changed the oil. I used some Marvel Mystery Oil when I changed the oil and now the engine is quiet as a new one. I don't normally use "snake oils" but I know MMO has been around for decades. It worked for me! Now I just need to order a new top from Russ and I'll be in great shape.
