I know these cars tend to run hot but I have a question.
First, I changed the stok thermostat to a 180 thermostat. Was the a good move or should I go to the 190?
Second, my fan kicks on at 225 degrees, with the new thermo, the difference in temp is even higher. I have an adjustible fan relay kit. Should I put it in and have the fan turn on at a bit higher than 180? Also, where is the switch/relay/sensor located that turns the fan on?
Thanks
