Author Topic: modding  (Read 4111 times)
Piojo
modding
« on: June 03, 2011, 03:25:00 PM »
am planning to install an intercool to my capri. i have all the kits ready. do i need rocketmans jpipe & vaf adapter so it could make it easier & keep the vaf going in the stock location? what does VAF stand for, just to be clear
modding
« Reply #1 on: June 03, 2011, 03:34:00 PM »
VAF adapter is a plate that goes over the filter side of the Vane Airflow meter to add a cone filter to your car.  Almost every single one of these will have to be drilled to fit a capri properly.  The JPipe is not neccesary, but if you're taking a large amount of the front apart, and he has any available, it's an affordable upgrade.
Piojo
modding
« Reply #2 on: June 03, 2011, 04:15:00 PM »
alright thanxx... does the blow off valve  decrease gas milage?
Yuri
modding
« Reply #3 on: June 03, 2011, 07:44:00 PM »
you already have a by-pass valve, which sends the surge back into the system. the blow off valve vents the surge pressure into the atmosphere. If you're going to be sending more pressure from your turbo, the stock bypass valve isn't really up to the task of handling more pressure than stock
any decrease in gas mileage is going to be from increasing the boost... or to be more specific, from you making the car go faster because it's more fun
modding
« Reply #4 on: June 03, 2011, 08:33:00 PM »
If you're going to install a cone filter - you will need a VAF adapter, whether it be mine or a cheap ebay/autozone type. Mine are direct fit & don't require drilling.
The Jpipe would be a nice upgrade, but works best with other uprades like FMIC + exhaust as those are more restrictive than the stock Jpipe is. Currently I don't have any kits ready to go but I can upon request.
BOV itself won't decrease mileage, but if you drive aggressively (they are fun turbo cars!) you will notice it at the pump.
Piojo
modding
« Reply #5 on: June 04, 2011, 04:58:00 AM »
i already the cone filter installed in my capri. thats a check on the list.. where can i mount the intercooler so it can be a perfect fit??
modding
« Reply #6 on: June 04, 2011, 10:01:00 AM »
Behind the bumper. That's about the only place it will fit
modding
« Reply #7 on: June 04, 2011, 01:26:00 PM »
I hope you took the bumper off and measured first.  Most intercoolers won't fit nicely in our cars, I'm pretty sure only shallow units with low widths fit.  I measured somewhere around 25 inches as about the max, with maybe 7 inches tall as a nice size, which would probably still require a decent amount of cutting.
modding
« Reply #8 on: June 04, 2011, 01:45:00 PM »
Open air BOV will decrease gas mileage on a car tuned to recirculate the BOV.
The VAF/MAF depending on the type of car, will calculate the air and send it to the computer to dump the proper air/fuel mixture.
Once you start venting the air your mixture becomes rich, eventually causing gas mileage to decrease.
modding
« Reply #9 on: June 04, 2011, 04:34:00 PM »
Quote
Have you read any of the 8 or 9 threads on here about people's installs? There's exact sizes posted, and little to no cutting needed. -__-
Quote
Jamie, did you notice an appreciable difference in gas mileage when you installed yours? I hadn't noticed any difference when I installed mine (on either of my XR2's I've owned)
modding
« Reply #10 on: June 05, 2011, 03:30:00 AM »
Yes, on every turbo car I owned
Piojo
modding
« Reply #11 on: October 14, 2011, 04:06:00 PM »
where can i get an intercooler for the capri?
modding
« Reply #12 on: October 15, 2011, 02:26:00 AM »
ebay
bhazard
modding
« Reply #13 on: October 15, 2011, 08:55:00 AM »
Id actually at some point like to recirculate my SSQV knockoff. The noise is getting old, and a slight boost in mpg cant hurt either.
That, and run the VAF in a blow thru config.
