Author Topic: 91 NA $500 firm  (Read 4644 times)
Capritain
91 NA $500 firm
« on: May 08, 2018, 02:34:23 PM »
I'm out of energy to work and modify on this vehicle.  If you are near and could drop by and towe it, $500 is a good deal.
as you can see, spoiler/wing looks good on Capri and this is one of a kind.
So as the modified front and back skirts.  All you need to do is sand it down paint to match and bolt it down.
Last known issue: engine gargling and then the starter went out trying to fix the gargling.  Many new parts which I probably mentioned here.
I like to get me a new running Capri Automatic or Miata Automatic. For now, I need room.
body are rusted out.
I'm in the center of Iowa which is almost the center of US so I should be along someone's path. Being said, I'm also close to the interstate if you are driving by I35/180. 1 minute away from i35/i80 mix master / interchange
91 CAPRAI N/A 5-Speed
D-town, Iowa
