Author Topic: Distributor Vacuum Advance Module  (Read 3159 times)
NiteLord
    • 91Cap,94Cap,86FieroGT,94G.C
« on: May 20, 2017, 07:12:56 PM »
..Has anyone ever rebuilt or were able to find a rebuilt Distributor Advance Module..??...My rubber diaphragm has obviously shrunk or has a rip in it causing the car to come to an almost stall condition at idle..I shot some carb cleaner into the vacuum module and the engine of course regains power. I have searched for a replacement but it seems you can't just buy the module you have to buy the Distributor also to get it and they of course aren't cheap...
Re: Distributor Vacuum Advance Module
« Reply #1 on: June 02, 2017, 08:58:05 AM »
You have a few choices. Find someone that is parting their car out.
More readily available are1988-89 Mazda 323 1.6L parts which many parts are the same. Here's a quick ebay search...
http://m.ebay.com/itm/272311156511?_mwBanner=1
My ignition module went out so I just bought the whole distributor. I'll take the vacuum advance off the old one if you are interested. Shoot me an offer and I'll help you out.
« Reply #2 on: June 02, 2017, 09:23:08 AM »
Eh, forget that idea. I took mine off. They are identical to the 323 except the angled mount bracket.
Pull this part# up in Autozone's search feature... JV1516 and you'll see.
I tested mine and it works. Rubber on the back side around the plunger looks rough but it still works.
NiteLord
« Reply #5 on: June 03, 2017, 08:11:32 PM »
...Thanks Mitch..I was able to find one at Advance Auto Parts Special Order Section...got it for $54 after discount..
