Author Topic: Front sway bar links  (Read 1898 times)
Kiwimagic
« on: August 02, 2020, 03:41:52 AM »
Has any body ever had to replace the front sway bar links on a 1994 SE Turbo..if you have .From where did you get them from. They arec not like all the other Capri's. They are shaped like a dog bone with a ball joint at each end. The ball joints have a 10 mm thread on each end and are about 60 mm apart.
cheers
Kiwimagic
Re: Front sway bar links
« Reply #1 on: August 03, 2020, 03:36:30 AM »
They're a much better design than the 91-93 style. One of 94XR2 only - things. I think? Did the NAs get swaybars with those links in 94?
Long shot, but maybe the ford dealer?
I can't recall of anyone replacing them, not to say it hasn't been done.
When I worked as a parts jockey at the local autoparts store, I remember seeing a fair number of similar links. I don't have the luxury of going through endless boxes of parts looking for similar stuff anymore.
I think the ones on my Hyundai are similar, I'll check them out.
If yours are good, keep em going
Kiwimagic
« Reply #2 on: August 17, 2020, 04:47:05 AM »
Hi
I found one that will do the job.
API 270071690
https://www.rockauto.com/?carcode=1206278
« Reply #3 on: August 17, 2020, 10:37:02 AM »
Is it suspected of working, or is it confirmed of working? An important distinction
It certainly looks pretty close, good work
« Last Edit: August 17, 2020, 10:40:27 AM by Rocketman »
