Author Topic: BOV Set Up...Show ME~~~  (Read 3197 times)
« on: April 29, 2009, 02:41:00 PM »
I am about to get a hold of a knock off HKS BOV mounted on a pipe already. looking at ways to install it. post some pics of your BOV set up. how did you delete the factory one. Pipes you replaced excreta... i need ideas!
Thanks
« Reply #1 on: April 29, 2009, 03:11:00 PM »
Heavensheros
« Reply #2 on: April 29, 2009, 04:03:00 PM »
I have mine set up the same way but welded on to the factory pipe. its better to go with rocketmans setup because the stop pipe is very small.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
« Reply #3 on: April 29, 2009, 05:34:00 PM »
it came mounted on a 2.5in pipe, i am thinking about getting the universal adapter instead and where the factory BOV hooked up to the pipe at the TB. plugging it in there. then making a new intake pipe set up for the air filter part. i will end up mounting it close to rockets way when i put on the front mount
JackRobot
« Reply #4 on: May 07, 2009, 10:40:00 PM »
Crappy mock up picture, but you get the idea.
« Reply #5 on: May 13, 2009, 07:36:00 PM »
