Pages: [1] 2 3 4
Author Topic: lowing springs!  (Read 36485 times)
aussie
lowing springs!
« on: April 14, 2003, 01:34:00 PM »
i was wondering if anyone is happy on how low there car sits! ive got suspenion tech springs just not low enough!!
ive cut coils off cars in the past and i know its now recommend but TUFF :) i was thinking of cutting off like ont whole coil i think that would lower it another 1''
anyone done this!!
djgaud33025
lowing springs!
« Reply #1 on: April 14, 2003, 03:40:00 PM »
I bought lowering springs from SSV and had them installed at a local tire shop. I don't think cutting the springs is safe.
djgaud33025
94 XR2
STE_6000
    • http://teamcapri.com
lowing springs!
« Reply #2 on: April 14, 2003, 03:46:00 PM »
I agree spring cutting isnt safe. Exspecial if you cut the wrong end and loose the stiff of the 2 ends.
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
clubsprint
    • http://www.clubsprint@verizonmail.com
lowing springs!
« Reply #3 on: April 14, 2003, 05:18:00 PM »
i have to agree i wouldnt cut for safety reasons i have h&r springs on mine it was a nice drop and ride i think i have about 1-2 inch fender well gap but very good handling
mhack
    • http://akdusa.com/xr2
lowing springs!
« Reply #4 on: April 14, 2003, 05:38:00 PM »
You should get coilover setup from corksport or any other place, this will allow you to change ride as you like..
  • Cone Air Filter (3\\" tube)
clubsprint
lowing springs!
« Reply #5 on: April 14, 2003, 05:41:00 PM »
yeah coil over is a very nice way to drop ride height
aussie
lowing springs!
« Reply #6 on: April 15, 2003, 01:33:00 AM »
BUT COIL OVER COMPRESS THE SPRING RIGHT?? WOULDNT THAT AFFECT RIDE AND HANDLE IF YOU OVER COMPRESS THE SPRING????
mhack
lowing springs!
« Reply #7 on: April 15, 2003, 02:53:00 AM »
Hmm.. I don't know what you mean, but every setup compresses the spring
Quote
STE_6000
lowing springs!
« Reply #8 on: April 15, 2003, 05:50:00 AM »
No. A coilover will not compress a spring more then if it was on struts alone. All a coilover doesnt is give a adjustable seat for the spring to sit in. Struts have a place that the spring sits in so it doesnt slide up/down on. A coilover sits where the spring would normally sit on the strut then providing a seating area in itself for the spring. The bottom seat of the coilover is where you typicly find a two piece design. One being the seat the other being the threaded cynlinder. The seat spins around the cynlinder allowing it you to adjust your ride hieght up or down. One warning. Springs from a coilover will not fit on struts alone. They area acctually little larger then standard springs for your strut. This is so that the spring doesnt come in contact at all with the strut during compression and decompression. Hope this helps and answers anyones question.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
tplay
lowing springs!
« Reply #9 on: April 22, 2003, 04:26:00 AM »
Hi!
I#M new here. I live in Austria, and it's very hard to get parts for the Capri Conv. Now I got some problems with law, because my car is to low.
They told me to put the original Springs in. But I don't have them.
Can I put all 4 Coil Springs from a Mazda??
Which Mazda what year? Model?
Please help!
Thanx in advance!
Dejan
STE_6000
lowing springs!
« Reply #10 on: April 22, 2003, 07:47:00 AM »
You can use struts and springs from a 86-89 mazda 323 non gt/gtx. Also springs from a mecury tracer, ford escort and or ford festia will work to for springs.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
Seth
    • http://www.auto-enthusiast.net
lowing springs!
« Reply #11 on: April 22, 2003, 11:17:00 AM »
The cops busted you for having it too low? That’s ridiculous, there are stock cars that could nearly get high centered on a pebble.    Is there some law down there that stipulates that you have to keep a car pretty close to factory specs?
STE_6000
lowing springs!
« Reply #12 on: April 22, 2003, 12:02:00 PM »
Well even the highest performance springs for the capri drop the car 1 inch the rest go even lower. These are all reading below stock spring height.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
clubsprint
lowing springs!
« Reply #13 on: April 22, 2003, 01:55:00 PM »
my h&r drop my capri a littl over 2 inches. i measured before and after
STE_6000
lowing springs!
« Reply #14 on: May 23, 2003, 02:22:00 PM »
Well it is finished. My baby is safely back home in my driveway. What happened today you ask? Well she got her new legs a new set of 4 HP struts and a new set of 4 coilovers and she is sitting with a nice 2 inch drop. Yep I did say coilovers.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
Pages: [1] 2 3 4
