April 27, 2024, 01:05:41 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri XR-2 89-94
Non-Interference Engine???
« previous
next »
Pages: [
1
Print
Author
Topic: Non-Interference Engine??? (Read 4538 times)
Carolina_Guy
Jr. Member
on:
December 23, 2003, 05:36:00 PM »
Does anyone know for sure if the 91 Capri XR2 engine is a Non-Interference engine??
Fiano
Sr. Member
Reply #1 on:
December 23, 2003, 07:06:00 PM »
1.6L SOHC & DOHC, 1.8L SOHC & DOHC 4-Cyl are a Non-Interference ENGINE JUST FIT THE BELT AND CHECK COMPRESSION if the valves are bent no compression but they cant be bent!!!
Carolina_Guy
Jr. Member
Reply #2 on:
December 25, 2003, 07:34:00 AM »
Thanks... Guess I will find out tomorrow for sure.. I'm going to install the new belt along with a new water pump.. The car will fly when it is running...but it sure is a pain to work on..
Carolina_Guy
Jr. Member
Reply #3 on:
December 27, 2003, 02:33:00 AM »
Well... I installed new timimg belt along with a new water pump.. Set timing marks on cams and crank and re-assembled... Tried starting but engine sounds as if it isn't firing at all... I know it is because I can see the arc if I pull a plug wire while trying to crank... I also checked compression on all four cylinders.. All four checked out at between 78 & 80 psi.. Any Suggestions??
zxtunerdotcom
Sr. Member
Reply #4 on:
December 27, 2003, 08:51:00 AM »
low compression on all 4 cyls and you just installed a timing belt... it's gotta be the cam timing.
i'll bet the cam or crank moved and put the belt off a couple teeth. line up the crank and see if the cams line up correctly.
rob
Carolina_Guy
Jr. Member
Reply #5 on:
December 27, 2003, 06:30:00 PM »
I took the timing belt cover off the cams and they still line up perfectly with the crank.. I was traveling around 55 mph when the belt broke.. I'm starting to wonder if maybe something in the computer or a sensor shut down when the belt broke running at that speed and needs to be reset...
Carolina_Guy
Jr. Member
Reply #6 on:
December 29, 2003, 02:50:00 PM »
Problem is solved... Cam pullys have 2 marks on each one of them.. One for intake and one for exhaust.. Both cams were timed with intake mark.. I knew something was wrong because a car doesn't have that much power with only 78 psi of compression.. Thanks Guys..
91capry
Newbie
Reply #7 on:
October 03, 2004, 04:33:00 PM »
ok wtf... i just did the same job and the cam timing is good according to your mess up because they are not both set on the same thing. but mine wont start, it cranks and cranks but it doesnt start, im startin to get pissed off at this two week project.
http://memimage.cardomain.net/member_images/8/web/428000-428999/428999_9.jpg\\
" target=\\"_blank\\">
D22A
Sr. Member
Reply #8 on:
October 28, 2008, 02:27:00 PM »
it,s means that if my timing belt will broke it,s will not damige VALVES?
1996 MT 3000GT LS
1993 CAPRI n/a
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Reply #9 on:
October 28, 2008, 04:19:00 PM »
It will not damage the valves.
Old-Timer
Reply #10 on:
October 28, 2008, 04:58:00 PM »
Hey D! The Capri motors are a non-interference motor. If you break a belt, fortunately you won't have problems with bent valves like numerous other motors would. Gus
Print
Pages: [
1
« previous
next »
Capri XR-2 89-94
