April 27, 2024, 06:29:53 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
General
General
Clutch
« previous
next »
Pages: [
1
2
Print
Author
Topic: Clutch (Read 5257 times)
Heavensheros
Old-Timer
Clutch
on:
July 30, 2009, 03:12:00 PM »
Just my car back from Friend ... put clutch in the car for 200 plus fee to get flywheel resurfaced ... its got a pretty stiff feel and will take a little bit to get used to but i am very happy with it. cant wait for the break in period to be over with !!.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
coco-customs
Full Member
Clutch
Reply #1 on:
July 31, 2009, 05:40:00 AM »
what kind did you get??
Not stoping till 300 WHP
Heavensheros
Old-Timer
Clutch
Reply #2 on:
July 31, 2009, 09:20:00 AM »
ACT 6 puck race disk with heavy duty PP
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
coco-customs
Full Member
Clutch
Reply #3 on:
July 31, 2009, 02:20:00 PM »
hows the engagement feel??Is it like a on/off switch or is it pretty smooth??
Tarheel49
Jr. Member
Clutch
Reply #4 on:
August 10, 2010, 03:57:00 PM »
Hey, speaking of clutches. I want to put in a new clutch in my 92 xr2. Putting in a chip, MBC,
fmic, 2 1/2 exhaust, and intake. Will a stock clutch hold up or do i need more?
Glenn
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Clutch
Reply #5 on:
August 10, 2010, 04:30:00 PM »
Depends on how old the clutch is. Answer is most likely.
Always a good idea to get a nice clutch though. Look at ACT, SPEC, centerforce, others can chime in too
Administrator
Old-Timer
Clutch
Reply #6 on:
August 10, 2010, 05:33:00 PM »
I'd say upgrade the clutch! I have a Rocketchip, MBC, fmic, 2 1/2 exhaust, and a hybrid turbo. I bought a stock clutch to save a few bucks. It works fine for normal driving, but will slip (alot) when I push it. Just ask Josh about my clutch........... :rolleyes:
Need parts?? Go to
http://www.Roo-Sport.com
bhazard
Sr. Member
Clutch
Reply #7 on:
August 11, 2010, 04:21:00 AM »
I have one of these, over 10,000 miles on it now and not a problem, its a little on the harsh side but I'd rather have that than slipping.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=xtd+stage+3+323&_sacat=See-All-Categories
Yep, ebay china clutch.
Tarheel49
Jr. Member
Clutch
Reply #8 on:
August 11, 2010, 04:22:00 AM »
Thanks. We have the trans out now. I just bought a new stock clutch and pp and had the flywheel resurfaced. I quess i should have asked before hand. I will see if they will take the clutch and pp back and get a good one. Better to do it now than to have to pull the trans again. Man what a job. I think it might be easier to pull the whole engine out the top than to drop the trans out the bottom. lol. If they don't take the clutch kit back, i will take $100.00 shipped.
Disk, PP and throw out bearing, all new.
Glenn
Administrator
Old-Timer
Clutch
Reply #9 on:
August 11, 2010, 04:50:00 AM »
Yeah, if you can put in a good clutch now...
I've run an XTD stage II clutch before, held up very well. I don't see them making a stage II anymore though.
I've found its easier to pull engine / trans out the top & work on everything there, I did pull the trans out the bottom once, NEVER again.
bhazard
Sr. Member
Clutch
Reply #10 on:
August 11, 2010, 05:38:00 AM »
I agree with pulling the engine and trans as one.
Its not too bad dropping the trans out of a festiva, the stock E-series can be lifted with 3 fingers. The G-series on the other hand, if youre a smaller guy you generally need help getting into place. Its like two festiva trannies.
Administrator
Old-Timer
Clutch
Reply #11 on:
August 11, 2010, 05:49:00 AM »
the biggest problems I had were pulling the lower subframe and driverside control arm bolts...and then getting the car jacked up high enough to try to maneuver the trans out. Pain in the ass!
being that you gotta remove all the subframe and all to me its just as much if not less to disconnect the engine and one more mount and pull it all out
Tarheel49
Jr. Member
Clutch
Reply #12 on:
August 11, 2010, 06:35:00 AM »
Friend of mine seems to think an act 6 puc disk with the new stock PP will be ok, or should i just bite the bullet and get the ACT complete kit? Disk and PP? Cheapest i've found so far is $368.00 for the kit.
Glenn
Tarheel49
Jr. Member
Clutch
Reply #13 on:
August 11, 2010, 07:44:00 AM »
Levermind, going with new kit.
Glenn
Administrator
Old-Timer
Clutch
Reply #14 on:
August 11, 2010, 08:00:00 AM »
I'll recommend the ACT Z62-HDSS kit which is the Heavy Duty pressure plate + the Super Street disc. Its a full face disk so its still plenty driveable, the 6 puck kits will have a harsher engagement.
The stock and cheap oem style pressure plates are crap. Don't bother with them...
Print
Pages: [
1
2
« previous
next »
General
General
Clutch
