Author Topic: Brass bushing shifter mod  (Read 4839 times)
« on: April 06, 2019, 05:52:28 PM »
I ordered brass shoulder bushings and shoulder screws to tune up my shifter.
McMaster-Carr
6 10mm flanged shoulder bushings 6659K14 @ $2.50 ea.
1 10X35 shoulder screw 92981A325 @ $3.06
2 10x50 shoulder screw 92981A307 $3.44 ea.
The major modification is drilling or grinding the peened head off the shoulder rivet.  Be sure and clean out the tubes prior to trying to insert the bushings. I had to use one factory bushing because the brass one wouldn't go into the tube.  Also add a washer under the head of the long screws.  The factory bolt is 48mm long, but they aren't available.  The bolt into the transmission is a royal PITA and getting the Allen wrench into it is also.  The payoff is a tight shifter that gives snappy shifts and will last for a long time hopefully.
« Last Edit: April 24, 2019, 12:13:27 PM by greywolf27030 »
belleaudb
    • 92 XR2
Re: Brass bushing shifter mod
« Reply #1 on: April 08, 2019, 12:32:15 PM »
I did mine April of last year as I had posted under non-capri usable parts. It's still smooth and noise free.
I'm sure you will be happy.   ;D
« Reply #2 on: April 24, 2019, 12:15:06 PM »
I'm very happy.  Did you use the stock shoulder bolts and what did you do about the rivet?
belleaudb
    • 92 XR2
« Reply #3 on: May 03, 2019, 05:26:33 PM »
Ground off the peened end of the rivet. I used a new non-shoulder bolt with locking nut.
