Author Topic: bore out  (Read 3748 times)
Heavensheros
bore out
« on: November 17, 2009, 01:29:00 PM »
so in the proccess of having my car taken apart, i was wondering what all parts on my car can i bore out to get a little extra power from.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
bore out
« Reply #1 on: November 18, 2009, 01:37:00 AM »
i ported out my throttle body, turbo coldside air inlet, and the throat of the turbo and outlet...
i lightly ported the exhaust side of my head, inside of my exhaust manifold and from the gasket side also... thare are no casting lines or marks in my intake or exhaust manifolds..
nice and smooth...
the trick is to get yourself a brake hone. (looks just like a cylinder hone but smaller)
made for honing brake piston cylinders..
i also have a 1.5in dingle berry hone or bead hone
... the bead hone works well to smooth out a vj-11 coldside all the way in the outlet to where it turns and makes the snail...
if you hone the inlet DO NOT hone where the turbo wheel spins inside the turbo!!
only the mouth opening...
the same goes for a throttle body..Just the opening, not where the butterfly sits...
smooth the air tract...
bore out
« Reply #2 on: November 18, 2009, 10:45:00 AM »
i would think you could do the cylinders to 1.8L
bore out
« Reply #3 on: November 18, 2009, 11:29:00 AM »
For the money you would spend at the machine shop and a new set of jugs and rings and what you would get out of the motor you would better spend your dough on a 1.8L BPT and get a lot of bang for your buck. The 1.6 and the 1.8 are not the same block and the 1.8's I have seen go to 1.9L..again senseless spending. Spend your money on a bigger turbo and stuff or a 2010 Mazdaspeed 3.
Clay
Heavensheros
bore out
« Reply #4 on: November 18, 2009, 12:36:00 PM »
can you sandblast the exhaust side of turbo ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
bore out
« Reply #5 on: November 18, 2009, 12:46:00 PM »
Sure you can but take off the center bearing housing.Did you get my PM??
Heavensheros
bore out
« Reply #6 on: November 18, 2009, 02:28:00 PM »
yes pm sent
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
