Author Topic: Couple Questions  (Read 3080 times)
nepacapri
Couple Questions
« on: April 05, 2008, 12:58:00 PM »
After my son decided to wash the engine I've decided to do some long over due maintance.  I replaced the plugs, wires, o2 sensor, fuel filter and some burned out bulbs.  Now I think it's time to finally change the struts and get an alginment.
1st question, If I go into the locle muffler/tire shop are they going to have parts or any idea what a Aussie capri is?  Or do I need to order the struts on line and have a local shop put them on.
2nd Q:  When the car is going straight, the steering wheel is turned a little to the left, when the car is aligned can the wheel get straightend out?
Thanks
spiro
    • http://N/a
Couple Questions
« Reply #1 on: April 12, 2008, 12:10:00 PM »
if its the original steering wheel you have, after you have done a wheel balance and aligment, then a camber/caster adjust, the steering wheel be cented again. I had the same problem...
spiro - 1989 SA Ford Capri
spiro
    • http://N/a
Couple Questions
« Reply #2 on: April 12, 2008, 12:10:00 PM »
"centred"
