Author Topic: Megasquirt/Microsquirt  (Read 2142 times)
belleaudb
    • 92 XR2
« on: March 04, 2020, 09:01:50 PM »
I'm thinking of converting to the Mega/Microsquirt system.
Either speed density or MAF.
Anyone have experience/recommendations on conversion?  I've not yet decided to go all the way to full ignition control. I know a miata CAS will work for
conversion to distributorless ignition.
I've got a ford/mazda breakout box to use for connection the mega/micro using the factory ECM connectors inside the car.
I'm figuring about $400.00 to go fuel control only and about $600 to go fuel/ign control.
I do know my way around efi. I used to convert GM TBI systems to Tuned Port Injection back in the 90's/early 2000's and could program and burn eproms.
Thanks.
Re: Megasquirt/Microsquirt
« Reply #1 on: March 05, 2020, 09:34:10 AM »
Recently saw this,
https://www.fueltech.net/
Also this:  https://pe-ltd.com/
« Last Edit: March 05, 2020, 09:40:27 AM by greywolf27030 »
belleaudb
    • 92 XR2
« Reply #2 on: March 05, 2020, 08:12:36 PM »
Thanks Jack..
I had seen both of those plus a few others on my search.
grab your ankles and hold your breath...   :o
Big $$$$$$$
I think those are for racing teams with huge budgets.
Seems like the Mega/Micro are the only options for the everyday enthusiast. Plus the Miata and 323GT guys have done some of the base mapping.
« Reply #3 on: March 06, 2020, 10:53:21 AM »
Cool, that will give you a kick start.
« Reply #4 on: March 08, 2020, 07:06:16 AM »
I ran a Megasquirt on my XR2 many years ago, fuel control only. Taking control of the ignition at that time was a bigger deal.
Fuel only was pretty easy, but the benefits of electronic ignition are huge. I kept the stock ignition because of the OEM knock controller but there are options for that now.
The Miata CAS will work. I think it lacks a bit of resolution though, but should be fine. The Ford EDIS-4 system was popular at the time, simple wiring with its own control module, but required a crank trigger. There are probably other options now, I have not been keeping an eye on that scene for some time.
Speed density seems to be the way to go, perhaps there are benefits to using a MAF system, but definitely get rid of the stock VAF. You'll need to use your ECU to trigger the fuel pump then.
Another option that was popular for a time at least for the BP guys was a Mitsubishi EVO ecu, it was hacked completely and was configurable to run other engines. Someone was making a kit +  drop in BP wire harness, though I don't think they are making them anymore. This could be adapter to run the B6D/T no problems
There's also a guy from the Festiva forum that started a new grassroots DIY ECU movement, rusEFI https://rusefi.com/
Seems to have gained quite a bit of traction, it's got some good features, and priced below that of Megasquirt I believe.
