Author Topic: A/C and Battery  (Read 3109 times)
Heavensheros
A/C and Battery
« on: August 20, 2008, 03:49:00 PM »
So imm plannign to do alot of work over the summer such as port/polished heads, VJ-11 swap, Intercooler, and other stuff like body work but imm gona start with removing the A/C and moving battery to the trunk. How hard would that be ?
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
Yuri
A/C and Battery
« Reply #1 on: August 20, 2008, 06:07:00 PM »
i haven't done it yet, but i know someone else has.. and i they said it's not too hard. im assuming it's just drilling through the firewall that's the hard part.
A/C and Battery
« Reply #2 on: August 20, 2008, 06:27:00 PM »
You can sneak the wires up inside the driverside fender and through the firewall, with the aux harness for the lights and such. Comes out just under the dash as far over as you can go. Then you can tuck it under the edge of the carpet just beneath the door.
Removing the AC...its just parts and a new belt. None of it is hard to do it just requires time and some $$ for the battery relocation kit
A/C and Battery
« Reply #3 on: August 20, 2008, 06:42:00 PM »
Hey Josh! Get the length figured out by stretching any kind of cord or string along the path that your cables will route and then go to a welding supply house and ask for #2 or #0 welding cable. They carry that in bulk. If they only carry black then you'll need to somehow mark one to differ it from the other. Way back when in my younger days, must of my buddies would run a ground through the bottom of the trunk to a frame rail. Also the welding supply will have the appropiate eye for the starter relay end of the cable. Use silver content soft solder to secure any cable ends and flush them of any solder flux afterward.  Good Luck  Gus.
Heavensheros
A/C and Battery
« Reply #4 on: August 21, 2008, 02:52:00 PM »
Ok cool that sounds like it shouldnt be to hard of a job to do imm prolly going ot make that a nice saturday project to move my battery to the back of the trunk  what all do i have to do to remove the A/C and what kind of belt would i need to get....
P.S.  Also rocket man i was looking on your site out of shear bordem and noticed you had bigger cam gears ,,, how hard of a job is that to do ??
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
A/C and Battery
« Reply #5 on: August 21, 2008, 08:01:00 PM »
Hey Josh!  I forgot to put in, any you pass an electrical wire or cable through sheetmetal one should install a gromet to prevent the cable coating from rubbing through and grounding out. In the course of the cable if you can't find the proper grommet then a piece of garden hose or other types of hose taped to the affected area will suffice to protect from cutting through the cable housing.  Gus.
A/C and Battery
« Reply #6 on: August 22, 2008, 12:17:00 PM »
I'm not sure what you are referring to about the cam gears - they are all OEM.
