its tells the ecm that the car is in neutral and when you push the clutch in you can start it if you short it or you could start the car when its in gear im think with out pushin in the clutch.. so its not bad but not good either its just a contact switch... it should not be bad just check it and see its just leakin make you a gasket to stop it from leakin
