Author Topic: Meth ingection kit  (Read 2514 times)
Heavensheros
Meth ingection kit
« on: July 20, 2009, 09:17:00 PM »
Has anyone seen these or heard of them or run them ? my friend showed them to me and was thinking it would be a good idea, just wana get a little feedback before i look into it.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
Meth ingection kit
« Reply #1 on: July 20, 2009, 11:13:00 PM »
Hey Josh! Unlike heroin where it is heated up in a spoon and then drawn in, meth is watered-up and then drawn in the injector. I choose to stay-away from either. I occasionally will over-load on tequila and then suffer afterwards the next day.  Gus
Meth ingection kit
« Reply #2 on: July 21, 2009, 04:21:00 AM »
Meth ingection kit
« Reply #3 on: July 21, 2009, 08:12:00 AM »
Meth or water injection can work pretty good...they're great for slapping a turbo or supercharger on a nonturbo car so you dont need an intercooler. However if your system relies on it in order to be safe, its not a great idea. They can clog or run out of fluid and then you're in trouble...
In my opinion you're better off replacing the junk restrictive stock intercooler and piping system with a larger and more efficient FMIC, and larger piping. It'll have the same effect and you wont need to fill it every few days.
Heavensheros
Meth ingection kit
« Reply #4 on: July 21, 2009, 09:40:00 AM »
could you run both the bigger intercooler and meth injection ? i was reading on-line and read that you can make them for around 60 bucks with a windsheild cleaner pump ect.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Meth ingection kit
« Reply #5 on: July 21, 2009, 10:33:00 AM »
you could but it would be redundant. also a winshield washer pump will never perform like a real kit. Real kits run upwards of 150psi...a washer pump will never do that. You might be better off spraying alcohol mix on your intercooler with a washer pump or maybe even two of them, they're cheap enough.
Most people who run both are over 20psi of boost on built motors with massive turbos and huge intercoolers that just wont cut it at that point
Upgrade your intercooler first, you wont need much more than that especially if you're running a stock turbo. I think Russ has one for sale that would work great for a stock turbo
coco-customs
Meth ingection kit
« Reply #6 on: July 21, 2009, 11:51:00 AM »
I have my snow performance h2o/meth kit ready for the 16g    cant wate
Not stoping till 300 WHP
