April 29, 2024, 06:02:04 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri XR-2 89-94
2 Repair Shops?
« previous
next »
Pages:
1
2
Print
Author
Topic: 2 Repair Shops? (Read 6703 times)
sterling94capri
Full Member
2 Repair Shops?
Reply #15 on:
May 18, 2011, 12:13:00 AM »
I cleaned the fuel pump ground. What did you use to clean the surface of the tank? I used a small file on the gromet nut. Anyway,no change in performance.On to the next guess!Rocky
sterling94capri
Full Member
2 Repair Shops?
Reply #16 on:
May 18, 2011, 06:31:00 AM »
What cars have the same TPS as ours? Are turbo and NA the same?Thanks Rocky
Administrator
Old-Timer
2 Repair Shops?
Reply #17 on:
May 18, 2011, 06:46:00 AM »
Do you need one? I have one sitting here from a turbo car......
Need parts?? Go to
http://www.Roo-Sport.com
sterling94capri
Full Member
2 Repair Shops?
Reply #18 on:
May 18, 2011, 07:05:00 AM »
My friend has a bunch of Escorts-we wanted to swap one and see if that was it? So if it works how much,and are turbo na the same?Rocky
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
2 Repair Shops?
Reply #19 on:
May 18, 2011, 01:32:00 PM »
Escort TPS is different. Turbo & N/A are the same
JJ
Sr. Member
2 Repair Shops?
Reply #20 on:
May 19, 2011, 04:22:00 AM »
If swapping the tps, there is an adjustment procedure. the book has a resistance reading one, and when Ford did mine, they got a voltage reading procedure from the Ford Hotline. That was posted here somewhere....
sterling94capri
Full Member
2 Repair Shops?
Reply #21 on:
May 19, 2011, 05:20:00 AM »
Fixed!Thanks for all the help. New plug wires did it. Had a pro(friend) make new grounds for the 3 by thermostat.etc.Lots of little things together made a pretty big problem. As soon as I get my boost guage installed I am gonna turn it up to 16lbs.Thanks again,Rocky.
Shocker
Newbie
2 Repair Shops?
Reply #22 on:
May 19, 2011, 10:00:00 AM »
Didnt you say in the first post that you replaced your wires??
Anyway good to hear that it running again!
sterling94capri
Full Member
2 Repair Shops?
Reply #23 on:
May 19, 2011, 11:43:00 AM »
No, I checked them. I didn't look at the distributer end carefully. #1 was all messes up.
Shocker
Newbie
2 Repair Shops?
Reply #24 on:
May 19, 2011, 01:23:00 PM »
Pretty sure you did! lol just messing with you
"Thanks JJ, I will go thru the thread in detail when I have a day off-in 7 days. I should have begun my post by saying tnat I have already swapped plugs,wires"
JJ
Sr. Member
2 Repair Shops?
Reply #25 on:
May 29, 2011, 04:13:00 AM »
glad you got it figured out! I still wonder why if the wires were bad why the problem was there with the tps inline, but without it the problem seemed to go away.... doesn't seem right to me.
sterling94capri
Full Member
2 Repair Shops?
Reply #26 on:
May 29, 2011, 05:57:00 AM »
I never touched the TPS? O2 sensor was un plugged,didn't help.Grounds need to be weather proof, I found this out the FIRST WINTER I drove the car!Rocky
Print
Pages:
1
2
« previous
next »
Capri XR-2 89-94
2 Repair Shops?
