All right guys - Koop and I need a little more help!! For background, the car was overheated due to a bad water pump, and had a warped head. Head was machined, and a valve job done. New plugs, and wires were also installed. The car is assembled, and WILL run. However, it won't start on it's own, and more often than not, won't start at all. The car seems to NOT start after it is up to temp. The check engine light is NOT flashing any codes, and all the guages read good. Car seems to act as if it is flooding. If Koop goes out in the garage in the morning, the car starts right up. After it warms up - nothing!
Planned checks/activites tomorrow:
TPS replaced
Computer replaced
Injector module replaced
Barometric pressure sensor replaced
if none of the above work, I plan on liberally applying 5 gallons of gas and a match!!
I really want this car to attend the MACG, but we have less than a week to get it in shape.
Anything you guys can think of that we can look at, check, connect, disconnect?
---Russ
