Author Topic: Hardtop install  (Read 12173 times)
Snigalfriz
    • 1991 NA Capri
Hardtop install
« on: November 14, 2011, 07:43:00 AM »
I picked am picking up a hardtop this weekend, and want to know how "hard" it is to install?
Does anyone have instructions?
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
luvit
  • imluvit
    • 93capri na
Hardtop install
« Reply #1 on: November 14, 2011, 09:05:00 AM »
sounds like you're driving-out your capri and hoping to throw it on right there.
take another hauler. this could be tough without the right torx bolts, if you're never done one.
see if the seller has the 5 torx/allen bolts included.
You need 5 bolts.
1 bolt each, above each sun visor.
1 bolt each, peering-down the exterior wall directly behind each front seat.
1 [large] bolt rear-center behind rear seat (may be covered with a round vinyl plug).
these bolts are 2-3" long, so make sure you have tested some bolts from Lowes prior to picking-up the hard-top.
once you successfully succeed, it's easire from then-on.
omgimluvit
tonlaw71
Hardtop install
« Reply #2 on: November 14, 2011, 09:12:00 AM »
The only advice I can give is....Don't try to do it yourself! Get someone to help you put it on the car. Once you get it in place, it will be very apparent what needs to be done. 1 bolt behind each sun visor, 1 bolt at each corner by the little windows and 1 bolt in the center at the back. Don't forget to connect the plug for the rear defroster. The wire will be down in the boot where the soft top folds into. Hope that helps!
///'92 Plasti-Dipped XR2\\\
Hardtop install
« Reply #3 on: November 14, 2011, 09:35:00 AM »
If the 3 bolts that are permanently attached to the hard top (2 side bolts, and 1 rear bolt) are not present, get some of your $$ back!
You will also need the 2 bolts that should already be in your car. Both are located behind the visors.
If you are not getting the factory hardtop tool, bring a 6mm allen key with you.
Dont forget to remove the center bolt plug on your boot cover!
If you need any of the bolts, or side trim, or any other part for your hardtop, let me know....I have a small stock of parts. Go to www.Roo-Sport.com, or email me at CapriTypeR@Gmail.com. You can also call me at:847-370-3760.
  www.Roo-Sport.com
Snigalfriz
    • 1991 NA Capri
Hardtop install
« Reply #4 on: November 14, 2011, 10:04:00 AM »
Thanks guys, I have a friend to help get it in place.
2003 Lincoln LS
2014 Chevy Cruze LT
Hardtop install
« Reply #5 on: November 14, 2011, 03:19:00 PM »
Personal recommendation since I don't have the tool for my car, invest in a ratcheting offset screwdriver.  They're at harbor freight for about $7 and include the correct allen head adapter you need and a nice low entry to clear anything, and it's a nice tool to have for other uses.
Hardtop install
« Reply #6 on: November 15, 2011, 01:16:00 AM »
My daily driver was wrecked in its past life, driver rear quarter panel and into the trunk was replaced, and putting a hard top on is a trick, the whole car is bent slightly.  This makes having the correct type mounting hardware a must.
You can buy almost the correct metric hex bolts from Ace hardware, but they don't have the shoulder area missing the threads so the bolts can float and be lined up easy.
 My last top had the bolts but they were a banged up mess, end threads were worn off.  I bought the bolts from Ace, then ground each one down using the old ones as a pattern.  Put them into an electric drill, clamping down on the threads, protecting them with a wrap of tin can material.  About 5 minutes each with a file and I had made new bolts.
Those bolts are 2 1/2 inches long, and the threaded area is about 3/4 inch, don't remember the thread specification, the bolts that are in the car that mount the front of the top can be taken to the store to get the right thread type.
Good luck with that top...remember if the headliner is sagging, there are lots of options for a different color that the grey, I have vinyl black with the tiny hole pattern circa 60's, and red on another...Chris
Hardtop install
« Reply #7 on: November 15, 2011, 04:50:00 AM »
Sounds like a lot of work and a whole bunch of time for a bolt that only costs a few bucks.
I have at least 30 of those sitting on the shelf. If you need any, let me know....
-----Russ
luvit
  • imluvit
    • 93capri na
Hardtop install
« Reply #8 on: November 15, 2011, 05:04:00 AM »
my previous owners stripped every hole.
i needed to slightly enlarge and re-tap each hole and buy new bolts.
omgimluvit
Snigalfriz
    • 1991 NA Capri
Hardtop install
« Reply #9 on: November 15, 2011, 05:39:00 AM »
luvit, try coating the regular bolts with jb weld and screw them in.  I have done this on stripped holes and was able to remove the bolts fine after drying.
2003 Lincoln LS
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
Hardtop install
« Reply #10 on: November 15, 2011, 05:41:00 AM »
Thanks for all the suggestions.
2003 Lincoln LS
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
Hardtop install
« Reply #11 on: November 15, 2011, 06:01:00 AM »
Are the threads from the bolts above the visor the same as the thread of the the back 3 bolts?
2003 Lincoln LS
2014 Chevy Cruze LT
luvit
  • imluvit
    • 93capri na
Hardtop install
« Reply #12 on: November 15, 2011, 07:34:00 AM »
2 above the visors are one pair.
2 behind the front seats is another DIFFERENT pair
1 one behind the rear seat is unlike the other pairs... if you don't have the original rear bolt, you may have to tinker with washers for the rear center bolt.
omgimluvit
Hardtop install
« Reply #13 on: November 15, 2011, 07:10:00 PM »
The 3 rear bolts are fixed to the top, and the front 2 are NORMALLY already attached to metal plates over the plastic covers where the visors are attached at.
Hardtop install
« Reply #14 on: November 15, 2011, 08:01:00 PM »
The rear bolts are commonly removed from the top, unfortunately
