Author Topic: shifter slop  (Read 7365 times)
zoom-zoom
    • 1994 capri and 1990 Reatta
shifter slop
« on: January 30, 2015, 11:12:16 PM »
My manual shifter seems very sloppy/floppy.  Not to the point Im grinding or missing gears but could be much tighter.  Are there bushings I can replace?  Thanks.
Re: shifter slop
« Reply #1 on: January 31, 2015, 02:06:16 AM »
There is a spring and bushing in the shift lever ball unit. They can wear and cause slop. That or the shift control rod bushing is worn or the bolt going through it is loose or worn.
Usually stuff like that was dealer only items. The only one that might carry it is Roo-sport.com
Some of the older ('86-'89) Mazda 323 stuff fits this car and the Mazda dealer still stocks stuff for their older cars. Its worth a check.
If nothing else find a junked Capri. I know of a good junked one in Chattanooga, TN craigslist. He will ship to you. Tell him you want the whole shifter and the control rod bushing. He is reasonable.
Re: shifter slop
« Reply #2 on: January 31, 2015, 07:53:09 AM »
I looked on http://roo-sport.com they do have the bushings and bolts. They even have the shifter. In the notes it says it requires 4 bushings.
Re: shifter slop
« Reply #3 on: January 31, 2015, 09:37:11 AM »
Generally a sloppy/buzzy shifter on these cars are caused by worn rod bushings. The bushing are cheap and fairly easy to replace.
I bought mine from Napa, part # ATM 0771303 they're only $1.49 a piece and as Mitch said, you"ll need four of them .
Re: shifter slop
« Reply #4 on: January 31, 2015, 10:02:15 AM »
I got mine at NAPA also.  They are also the same as a Festiva.  One thing to note is that the rivet at the front end is a shoulder rivet and the correct end has to be ground off to get it out.  Ask me how I know.  Use a correctly size screw with either a self locking nut or double nuts so that the screw has some free movement in it like the one under shifter.  The front ones were actually my problem and replacing them made a tremendous difference.
wcdeangelo
    • 92 capri xr2 jeep 95 cherokee
Re: shifter slop
« Reply #5 on: April 06, 2015, 07:20:53 PM »
i pulled the shplder bolt out and put in a roll off a beer can side. worked great
Re: shifter slop
« Reply #6 on: April 07, 2015, 07:38:03 PM »
That's great! :)
...and you thought you were done with that beer when ya chugged it.
deewoody
    • 1993 Capri XR2
Re: shifter slop
« Reply #7 on: November 28, 2015, 09:33:29 PM »
hello fellow Capri drivers... where do i go to access the bushings ,so as to replace them ? is it at the shifter, in the cabin?  or do i have to go underneath the car?  thanks
Re: shifter slop
« Reply #8 on: November 29, 2015, 01:00:37 AM »
Under the car, I do mine with front wheels on ramps.  Put a big piece of cardboard box down, makes sliding u
nder easier.  If you have someone jiggle the shifter for you, you will see where the slop is, and where the bushings need to be changed.
deewoody
    • 1993 Capri XR2
Re: shifter slop
« Reply #9 on: November 29, 2015, 12:37:37 PM »
thanks blueamber.. appreciate that. will i have to remove anything thats in the way, or will they be accessible to replace easy enough ?
