Author Topic: will not start.  (Read 3970 times)
Kiwimagic
will not start.
« on: November 17, 2022, 09:02:00 PM »
Engine turns over but will not fire.
Fires and briefly runs if fuel is sprayed into throttle body.
Are the fuel injectors protected by a fuse?
If they are where is it located?
It is not shown on any of the wiring diagrams I have.
The car has spark and fuel but will not start.
Started and ran well before a replacement throttle cable was fitted.
any ideas?
cheers
kiwimagic
Re: will not start.
« Reply #1 on: November 18, 2022, 05:00:01 AM »
Is it possible you have the throttle cable/stop adjusted too tight, forcing the throttle plate fully closed at idle? It won't run with no air.
