Thanks guys. Like Sceeter said, I removed the wire clip (without destroying it). It had a split in it that I hadn't seen before so removing the clip was a breeze. After that, everything came apart like nobody's business.
Here are some pix for the next guy that needs to do it.
You can see the wire clip in this picture:
Here's the wire removed from the inner CV joint:
Next step is to remove the circlip:
Tap it with a hammer if it's a bit stuck. It should come out really easily.
This is the driver's side shaft.
This is the end that slides into the transmission. I got the axle out by using a crowbar and a good yank.
Thanks again!
Dave
