Author Topic: What Tranny Fluid to Use?  (Read 5277 times)
« on: February 21, 2009, 04:47:00 PM »
what fluid should i use, pep boys could only tell me about Automatics
bryanknight
« Reply #1 on: February 21, 2009, 07:12:00 PM »
that 5 speed takes mercon and the book says mercon 2 but i thinks its merson 3 now but the auto parts does have that type
bryanknight
« Reply #2 on: February 21, 2009, 07:13:00 PM »
sorry its mercon 3   i miss spelled it the second time
bryanknight
« Reply #3 on: February 21, 2009, 07:14:00 PM »
and it hold 3.4 qts
« Reply #4 on: February 21, 2009, 09:08:00 PM »
sweet thanks....
bhazard
« Reply #5 on: February 22, 2009, 05:20:00 AM »
I used valvoline full synthetic atf in my festiva's 5speed. Butter.
1992xr2
« Reply #6 on: February 22, 2009, 05:40:00 AM »
I'm a huge fan of redline fluids for everything but the oil.
\\\'90 Civic Si
Boost in the near future.
« Reply #7 on: February 22, 2009, 08:54:00 AM »
Service manual calls for ATF. I'm running 80w90 Valvoline gear oil in my tranny, a lot of people say its too thick but I haven't had a problem with it yet.
If you do some research on manual transmission fluids you should be able to find something that would be ideal. I havent got to that point yet.
« Reply #8 on: February 22, 2009, 11:15:00 AM »
Hey Gost!  I'm running 80/90 in the two cars I drive regularly. I'm in just a tad cooler climate than you. Also I run 20/40 or 20/50 in the non-winter months in the motor.  Gus
« Reply #9 on: February 22, 2009, 11:56:00 AM »
sounds like you can use just about anything that lubes huh..LOL
littlegaygreen
    • http://myspace.com/bobbyjbrown
« Reply #10 on: February 22, 2009, 02:31:00 PM »
all depends on where you live mine already had atf so i used atf with lucas
93 xr2, cone filter,no cruise,boost gauge,ALL NEW IGNITION AND STILL RUNS LIKE POOPY
\\"\\"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.\\"\\" (STOLEN QUOTE)
« Reply #11 on: February 22, 2009, 05:11:00 PM »
who knows what mine had. it just looked bad when it leaked so i want to swap it out....
delhiboy3732
« Reply #12 on: September 06, 2009, 11:36:00 AM »
How about Mobile1 75/90?
« Reply #13 on: September 06, 2009, 12:50:00 PM »
Hey Delhiboy! Excellent choice!..Gus
delhiboy3732
« Reply #14 on: September 16, 2009, 03:43:00 AM »
Thanks Gus.
So really is the tranny oil capacity 3.4 quarts? That seems to be a lot of oil for this little car.
