Author Topic: 16G Turbo on our Capri.....  (Read 7453 times)
« on: April 09, 2009, 02:31:00 PM »
anyone here have a turbo other then the hybrid one. i found this guy running an EVO III turbo. i had one on my eclipse and loved it. i think it would make a ton of power for our car. it can boost 14-18 PSI all day long!
http://www.cardomain.com/ride/2241793
JackRobot
« Reply #1 on: April 12, 2009, 03:22:00 PM »
I'd like to know more as well.
1991 Mercury Capri XR2 - Project car
1991 Mercury Capri XR2 - Daily driver
1986.5 Nissan Hardbody project minitruck
« Reply #2 on: April 12, 2009, 03:55:00 PM »
i tried to check out the website of who made his manifold but did not see one there.
just the photos can at least give an exhaust shop an idea to make one. there are so many of the 16G turbos out there the support is endless for them
« Reply #3 on: April 12, 2009, 03:59:00 PM »
Yeah thats Ian, he parted the car out about a year ago. Said he needed the money.
After he installed the big turbo he was running a custom Rocketchip...he said it ran awesome, AFR's were good
« Reply #4 on: April 12, 2009, 04:34:00 PM »
anyone here a welder?
« Reply #5 on: April 12, 2009, 05:31:00 PM »
I believe he had those bits made by Neukin. They dont do stuff for the B6T anymore.
Xr2fast87
« Reply #6 on: April 16, 2009, 12:21:00 PM »
I can weld quite well, ASME certified.  what did you need done?
« Reply #7 on: April 16, 2009, 05:09:00 PM »
check out the link in first post, he has a manifold that can fit a 16G turbo on it.
would love something that would do the same thing.
« Reply #8 on: April 16, 2009, 05:45:00 PM »
Order a JGS tools log manifold, you can order whatever turbo flange you want. I'm pretty sure they have most mitsu turbo flanges available
« Reply #9 on: April 16, 2009, 06:14:00 PM »
i found the website
so it is basically a build your own manifold?
« Reply #10 on: April 16, 2009, 06:33:00 PM »
pretty much, you can order them in different stages of completion but you'll still need a little welding done either way you go about it
« Reply #11 on: April 17, 2009, 01:58:00 AM »
so the flange at the exhaust manifold for a 1.6 non turbo and turbo are the same where it bolts to the eng?
« Reply #12 on: April 17, 2009, 09:48:00 AM »
yes all 1.6 dohc flanges are the same. (with the exception of the B6 in the 94+ MX3, that had a revised head)
So even a cheap OBX miata 1.6 manifold would work, they make them for the 16g, just cut & re-weld the turbo flange
« Reply #13 on: April 17, 2009, 04:47:00 PM »
thats what i was thinking, use one from a miata set up, i guess if i ent with a slimline fan set up and removed the AC crap and put the fan on the front side of the radiator that there would be enough room to put a 16G in there
