Pages: 1 [2]
Author Topic: bypass valve  (Read 8702 times)
annie151
bypass valve
« Reply #15 on: June 15, 2009, 05:13:00 AM »
wow learn something new everyday.
Thanks....here's the image....
http://i616.photobucket.com/albums/tt242/annie151/bovvalve.jpg
Phillip
bypass valve
« Reply #16 on: June 15, 2009, 06:25:00 AM »
I might be incorrect but... I think it is in backwards????
annie151
bypass valve
« Reply #17 on: June 15, 2009, 10:31:00 AM »
really?
I don't think it will hurt it if I turn it around...I can try it.
bypass valve
« Reply #18 on: June 15, 2009, 10:52:00 AM »
It does look like it is installed backwards - can you get a picture or describe the ports on it? Try running the recirc as open (plug off the return to the pipe first) you should hear a pssshhht or woosh as a blowoff. If not then it is in backwards.  Did you happen to get a diagram with it?
annie151
bypass valve
« Reply #19 on: June 15, 2009, 10:57:00 AM »
No, I did not get instructions...this is the one I have ordered on ebay...per your instructions.  I have contacted the person selling it and she said just remove the old one and install the new one...I gave up.
bypass valve
« Reply #20 on: June 15, 2009, 11:02:00 AM »
Okay, I do think its in backwards. The center port should have a piston in it - that piston will move toward the cap with the vacuum line attached, letting bypass boost out the side port. Try switching it around and let us know how it works. It might partially work in the current configuration but they generally rely on the boost to help push the piston open.
annie151
bypass valve
« Reply #21 on: June 26, 2009, 07:53:00 AM »
That worked...MY Heros
Pages: 1 [2]
