Tech, Repairs, Upgrades => Capri N/A 89-94 => Topic started by: Gman on September 06, 2023, 09:22:26 PM
Not getting fuel to the cylinders. Fuel pump working fine. Searched the forum and read to check the relay. What is the best way to check the relay? I found new and used relay on eBay. I want to check before I spend money on one.
My first one had that problem when I got it. Turned out to be a broken wire in the harness under the battery, simple fix.
