Author Topic: Vent drain  (Read 2302 times)
herdfan75
    • 94 Capri XR2
Vent drain
« on: September 10, 2018, 08:16:09 PM »
Still chasing down the musty smell in my Capri. Is there a drain for the vent at the back of the hood/below the windshield?  I know leaves get down in there so surely there’s a drain for water. Where does it exit?
herdfan75
    • 94 Capri XR2
Re: Vent drain
« Reply #1 on: September 11, 2018, 06:00:24 PM »
Any ideas?  ;)
Re: Vent drain
« Reply #2 on: September 13, 2018, 06:33:45 PM »
The only drain I know of is for the A/C, which may be connected to drainage for the vent intake opening.  If that hose is clogged the passenger gets water sloshed onto their feet.  It's a black hose, small diameter, passenger side, near the firewall.
Re: Vent drain
« Reply #3 on: September 14, 2018, 10:17:44 AM »
I haven't looked, but fender vents are normally slots on the inside at the bottom of the fender.  Sometimes you have to remove the fender to clean them.  Of course rust is always a problem when trash accumulates and holds moisture in there.
herdfan75
    • 94 Capri XR2
Re: Vent drain
« Reply #4 on: September 17, 2018, 03:18:44 PM »
I believe the drains are at the top corner of the fenders as I found a bunch of debris down in there. I'm going to try to flush those out and get all the gunk out of there.  I'll report back.
