April 29, 2024, 01:29:44 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri XR-2 89-94
valve cover
« previous
next »
Pages: [
1
Print
Author
Topic: valve cover (Read 2233 times)
Heavensheros
Old-Timer
valve cover
on:
November 10, 2009, 04:49:00 AM »
how hard is it to remove the valve cover to change the gasket. is just as simple as move pipe and remove screws and pop off or is there important steps i should know of ?
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
delhiboy3732
Jr. Member
valve cover
Reply #1 on:
November 10, 2009, 05:01:00 AM »
Yup, you know it. Just remove it, remove the old gasket, clean the base, install the new one, some people like to use black silicone with it at some places.
Screw back the valve cover.
Old-Timer
valve cover
Reply #2 on:
November 10, 2009, 02:45:00 PM »
and do not over tighten....
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
valve cover
Reply #3 on:
November 11, 2009, 12:27:00 PM »
VC bolts should be a little more than wrist tight using a wrench. Dont forcefully tighten them.
You should carefully clean each corner and use some red or black RTV sealant as said above, at the corners of each camshaft cap and also the dizzy cap
Heavensheros
Old-Timer
valve cover
Reply #4 on:
November 12, 2009, 04:14:00 AM »
ok thanks for the advice i was told also to use some silicone to keep the gasket in place idk im having a friend who is real good with cars put the gasket back on and such.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Print
Pages: [
1
« previous
next »
Capri XR-2 89-94
valve cover
