Author Topic: "Dieseling" sound when accellerating  (Read 7426 times)
« Reply #15 on: December 22, 2011, 05:14:00 AM »
Is there actually any noticeable reduction of power when it's making the noise?  If not I highly doubt that it has any sort of miss.  Granted, a high-end miss is possible; but very unlikely unless your plug wires are coated with oil or your plugs are bad.
Snigalfriz
    • 1991 NA Capri
« Reply #16 on: December 22, 2011, 12:40:00 PM »
No power loss.  The plugs and plug wires are new.
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
« Reply #17 on: December 29, 2011, 07:14:00 PM »
It was the timing, had it checked and set and the knock is gone.
2003 Lincoln LS
2014 Chevy Cruze LT
« Reply #18 on: December 29, 2011, 07:40:00 PM »
Thank you for the update!
Snigalfriz
    • 1991 NA Capri
« Reply #19 on: December 31, 2011, 04:14:00 PM »
They called it a "spark knock".
2003 Lincoln LS
2014 Chevy Cruze LT
