thanks for the info. have spark, fuel, compresion
checked distributor on another Xr2 have, timing
belt right on, checked VAF, all grounds. car starts runs rough quits. plugs are gas fouled.
injecters are still running when engine is off,
and key is on. my cousin is a ford dealer
mechanic,and said this is not uncommen. problem
of ECU. I will know when I test it in friends
Xr2 this weekend. will check out your ECU'S if
that is the problem. have boost valve installed.
Mike 93Xr2
