Author Topic: Stroker kit?  (Read 4967 times)
bratboy_y2k
    • cars
Stroker kit?
« on: June 29, 2019, 07:45:05 PM »
Do stroker kits exist? Or is there a setup to increase cubes?
Re: Stroker kit?
« Reply #1 on: July 01, 2019, 02:14:38 PM »
A BP is an instant increase and Miata internals fit our B6.
Re: Stroker kit?
« Reply #2 on: July 02, 2019, 12:37:44 AM »
The B6 in our Capri’s is essentially a stroked out 1.3L block and the spacing between the cylinders is too small to overbore any further.
If you’re looking for more displacement, go with the 1.8L BP like me and a few others have done.
Re: Stroker kit?
« Reply #3 on: July 02, 2019, 09:01:07 PM »
The BP has 2 stroker kits available, 1 for 2.0L from Flyin Miata, and another for 2.2L from Maruha Racing IIRC. Both are around 2-4grand. The perfomance increase is around 60hp for a stock motor and much more for a boosted application with supporting mods/ecu and such. Ive looked deeply into it and the Flyin Miata one from what ive hheard/seen is the most reliable as it uses H-Beam rods and forged pistons with many different compression ratios based on needs.
Re: Stroker kit?
« Reply #4 on: July 02, 2019, 09:32:25 PM »
There was a 1.6L stroker kit back in the day but it was stupid expensive.
It's far better to swap to BP, it's a better platform to start with. There was a BP stroker kit too but again stupid expensive
