April 27, 2024, 03:13:01 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Brakes/Suspension/Tires/Wheels
sway bar stabilizer links
« previous
next »
Pages: [
1
Print
Author
Topic: sway bar stabilizer links (Read 3259 times)
kraversxr2
Newbie
on:
February 12, 2012, 08:14:00 PM »
I was looking on line at sway bar stabilizer links and was wondering if the links were the same in the front and back. they have a couple different #'s but they just seem to be manufacturer #'s. one company lists front while another lists back but the same part #. Does anyone know if there is a difference between the two? They both look very close. I did notice that on the mazda parts list for the 89 323 the only difference between the two was the link bolt had a different #. Mabe the front has a longer bolt to get thru the front crossmember? :confused:
Guest
Reply #1 on:
February 14, 2012, 11:06:00 AM »
Just a tip from a parts guy. All sway bar links are essentially the same. All you watch for is length, and the spacer. Cups and bushings are almost universal. When I replaced my fronts I just used ones for an escort with the capri spacer, works fine.
Print
Pages: [
1
« previous
next »
