Author Topic: Help electrical issues  (Read 4128 times)
Freeeric2023
    • 1991 non turbo capri
« on: May 24, 2023, 11:37:01 AM »
I need help. I got a 91 non turbo capri and it has electrical issues. I installed a new fuel pump and got car started. Then I replaced alternator because it wasn’t charging. It ran fine for a day then it started cranking as soon as I turned the ign switch to the on position. I can’t figure out what’s going  on. Thanks
NEDREBEL
    • 19 RAM, 91 XR2, 78 VOLARE, 67 RAMBLER REBEL
Re: Help electrical issues
« Reply #1 on: May 25, 2023, 02:12:05 PM »
My first guess would be ignition switch. Mine wouldn't engage the starter, I tried chasing it. I gave up and put a starter button on the dash.
Freeeric2023
« Reply #2 on: May 29, 2023, 12:06:12 AM »
It’s not the ignition switch I checked it
« Reply #3 on: May 29, 2023, 08:54:51 AM »
Check the signal wire going to the starter motor. You should also check the fuses in the under-hood fuse box (near the LH strut tower)
Freeeric2023
« Reply #4 on: July 08, 2023, 07:30:46 AM »
I figured out that voltage was coming from ttransmission position part of starting circuit as soon as key turned to on position. Anyone know why this would happen
