Author Topic: headlight reminder kit  (Read 5088 times)
annie151
« on: March 18, 2008, 08:36:00 AM »
I'm forgetful sometimes(most times) and I tend to leave my headlights on whenever I use them in the daytime. I know the obvious answer is to not use them in the daytime, but certain situations call for it. I would like to build a noisemaker of some kind that will remind me to turn off my lights when I take the key out of the ignition. Is there some kind of relay I can use that is an open circuit when power is applied and a closed circuit when the power is cut off? You know, backwards from a normal relay. I'd prefer not to have the headlights themselves pass through a relay of any kind- if possible
GrooveNerd
« Reply #1 on: April 03, 2008, 09:02:00 PM »
Many relays have both Normally Open (NO) and Normally Closed (NC) terminals on them.  The relay commonly used for aftermarket fog lights has both terminals.  Hella, Bosch and others make them, and they are available at most auto parts stores.  They usually have terminal numbers 30, 85, 86, 87 and 87a on them, and many have circuit diagrams printed on the side or top.  There are some that have two NO output terminals, but you want one with a NO and a NC terminal.
1993 Capri XR2, Emerald Green (123,xxx mi)
1998 Contour SVT, Black  (159,xxx mi)
1987 Escort Wagon, Met. Blue (271,xxx mi)
1982 Escort Wagon, Silver (372,xxx mi)
annie151
« Reply #2 on: June 27, 2008, 06:47:00 AM »
I found something that could be used, if you do not want to go through all the wiring.  The item is called "LIGHTS-ON ALARM" on the JC Whitney Web-site.  They have all kinds of little cool stuff for your car.  Alarm beeps until you turn your lights off. Mounts with double-sided tape. Approx. 1" L x 5/8" W x 1/2" H.
ElwoodRacing 91XR2
« Reply #3 on: June 27, 2008, 02:33:00 PM »
Mine has something installed that beeps if I leave the headlamps on with the key off.  The guy who owned my car did all sorts of cool electrical stuff to it.  I'm glad he installed the headlamp reminder, several times it's saved me.  He also wired the fog lamps as DRLs and I can have the fog lamps on w/ the parking lamps.  I like driving around like this.  Sorry I can't tell you what he did, but I'll beat the  Capri Meet in Indiana, if you want to check out my heap.
annie151
« Reply #4 on: June 30, 2008, 05:44:00 AM »
Could you please give me more information about this meet...when and where?
« Reply #5 on: June 30, 2008, 07:50:00 AM »
Annie151-
Here is the link with the info for the meet:
 2008 MACG
Scroll down the page to the post from "RicksService".  All the info is there!!
Hope to see you in Indiana!!
