Author Topic: 93 non turbo auto performance wierdness  (Read 3076 times)
pothos
« on: May 18, 2010, 10:55:00 AM »
Hello All,
I have a 93 auto in VGC that has developed an intermittant "fart & pull"*(*TM).
Anyway....more often than not when I accelerate, the car seems to have an irregular miss that can be felt in the car's motion. Sometimes, it runs fine.
I have replaced plugs, fuel filter, PCV valve, distributor cap & rotor...
Is this maybe a timing thing? A vacuum leak? or any ideas?
Thanks,
Phil
pothos
« Reply #1 on: May 18, 2010, 10:58:00 AM »
Sorry, I put this in the wrong spot...my performance is a bit off as well!
Phil
Phillip
« Reply #2 on: May 18, 2010, 11:02:00 AM »
Check the wires and replace if needed. Probably do.
pothos
« Reply #3 on: May 20, 2010, 04:54:00 PM »
Thanks,
I'll inspaect my wires, but they sure look good.
May have my injectors cleaned in a shop......
pothos
« Reply #4 on: July 14, 2010, 10:07:00 AM »
Phillip,
You were right....even tho' the wires looked fine I replaced anyway & "end of problem".
Thanks
Hollis
« Reply #5 on: July 16, 2010, 07:20:00 PM »
Hmm I have same problem on my xr2. But my plugs are only 8 months old.... I might try a set out from autozone to see if it fixes it. I can't seem to get this thing running right. I swear I have electrical gremlins...
I mean I got the car with the horn unhooked and it didn't work. One day randomly it worked...
