Pages: 1 ... 21 22 [23] 24 25
Author Topic: My Capri  (Read 120345 times)
tellerx
My Capri
« Reply #330 on: February 28, 2011, 05:20:00 PM »
Hey i see that u have a miata style bar on ur Capri hows about a snapshot of the brackets i need to see them to get an idea of the complexity in making my own
My Capri
« Reply #331 on: February 28, 2011, 08:44:00 PM »
Josh has a custom fabricated rollbar he made, it bolts to the floor & his seat harnsses mount to it. His would actually work!
Heavensheros
My Capri
« Reply #332 on: March 01, 2011, 02:28:00 AM »
the seabelts mount in the back where the stock back seat belts bolted to and the roll bar was just 2 peices of muffler pipe i had bent and then welded 2 muffler flanges to the bottom of them and then sat into the car, they actually did not bolt into the car they were held with some hidden latches behind them that bolted to my back speaker box, i have them but dont use them anymore.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
Heavensheros
My Capri
« Reply #333 on: March 02, 2011, 05:02:00 PM »
ok so i did some more work to the car today, some little things but they make a difernece,  first i fixed my windsheild wiper motor so now my wiper blades dont stop mid eye sight, what a relief, then i changed my tstat and here are before and after pics for Rocketman
before after driving for about 30 minutes
after, after driving for 30 minutes, now my car runs a little better and seems to be running more lean at idle/cruise maybe ill have better fuel now HAHA
i got around to also doing my rear speakers there now in i dont have a pic of the speakers in but i will soon, here is a comparison of the door speakers and the rear speakers
rear(right) is an 8" midbass woofer door speaker (left) is a 7" midrange speaker
i also am working on getting rid of my hood rattle and cleaning her up a bit with some sound deadner ( good up to 500 degrees ambient heat)
also painting the hood clip (or what ever its called)
paint is 500 degree engine enamal then will coat with a clear lacquer so it should be able to hold up to the use of the latch.
and thats all she wrote
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
My Capri
« Reply #334 on: March 03, 2011, 01:23:00 PM »
ok got the hood done and HOLY #@$! it sounds like a brand new car!!! i used silicon for the seams, sound deadner for the hood area and then filled the braces with exspading foam, it added probably 2 lbs to he hood so it doesnt make a difference in weight but it sounds AMAZING !!!
and here a vid
also i got a chance to take a picture of my wire up front
thats 0AWG welding wire one goes to the back where the battery is the other is connected to the alternator and then the third wire goes to the second distributor block
both blocks and the wire
thats 0AWG from the other block and 2 4AWG wire one goes to the fuse panel and the other goes to the starter, everything is welded and heat shrunk for best results, i dont have a picture of the grounds but on the Passenger side i have a 0AWG ground from strut mount to engine block and on driver side i have a 2/0 AWG wire going from frame to tranny case.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
My Capri
« Reply #335 on: March 03, 2011, 05:41:00 PM »
Put some tubing or clamp it over the fuel filter.....so it wont chaff the wires
Heavensheros
My Capri
« Reply #336 on: March 04, 2011, 02:44:00 AM »
that thats in the process im getting a bunch of wire clamps and clamping it down also going to get wire loon for all the wire
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
My Capri
« Reply #337 on: April 15, 2011, 03:33:00 AM »
Some small stuff i did to the car, removed Power steering pump, cleaned up the engine bay and covered all hoses with hose loom i got for free
pics will be coming soon, also finished my car audio and did a quick video metering the SPL of my sound system, im very happy
 http://www.youtube.com/watch?v=YrEeZ3wx534
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Colorado1
My Capri
« Reply #338 on: April 15, 2011, 12:54:00 PM »
I like the gauge placement. I went lower just above the ash tray. I probably would've gone your route & got rid of the stupid cup holders. Nice job
Heavensheros
My Capri
« Reply #339 on: April 16, 2011, 12:50:00 PM »
mine didnt have cup holders it had the little pocket thing and thats where the gauges actually sit in like this
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Colorado1
My Capri
« Reply #340 on: April 18, 2011, 10:45:00 AM »
Maybe I'll pick one up at the junkyard sometime. I don't know your set up but the first time I was looking at your pictures I noticed the plastic vacuum line going to the drivers side on intake. Is that for your boost gauge? I was told to run mine to the passenger side nipple vac hose. If it is the for the boost was wondering if it makes a difference. Mine reads correct on vac & boost. Thanks, Rob
My Capri
« Reply #341 on: April 18, 2011, 11:57:00 AM »
Any nipple on the plenum will work correctly, except for the one or two on top that go to the distributor.
The pass side works well because a lot of people disconnect the boost cut switch, opening up room
Colorado1
My Capri
« Reply #342 on: April 18, 2011, 02:52:00 PM »
Thanks Rocketman, nice to know neither is wrong!
Rob
My Capri
« Reply #343 on: April 18, 2011, 03:08:00 PM »
If you need one of those pockets, I got one, cheap!!
Colorado1
My Capri
« Reply #344 on: April 19, 2011, 10:01:00 AM »
Thanks Russ, but I'm lucky enough to have a couple cars @ the local yard to scrap off. Ones even the same goofy green as mine. I've only seen two driving, a black & grey one so there's not much competition either. I need to sell a few on eBay. Got my original ECU if anybody needs one. Remember it's my driver so I had to go junkyarding to send mine to Rocketman. Theres another ECU @ the yard now also ssoooo?thanks though, I always know you have what I might need. Rob
