Pages: 1 ... 4 5 [6] 7 8
Author Topic: MY XR2 PROJECT/BUILD!!  (Read 42567 times)
« Reply #75 on: July 01, 2010, 02:23:00 PM »
Get a bigger intercooler...you will need it with that set up..
Heavensheros
« Reply #76 on: July 01, 2010, 04:13:00 PM »
or try and get liquid to air intercooler ? i was looking at those online and there not that exspencive.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
coco-customs
« Reply #77 on: July 01, 2010, 04:52:00 PM »
My intercooler is plenty for the setup. It's a Precition 350HP core that's known to be one of the best not a e-bay special. Any bigger and it's just a waste of pressure. One of the main goals for me is to reduce pressure drop and to try to keep spool time as quick as possible that's why I went with 2" IC piping on the turbo side and only 2 1/4 on the throttle body side. Josh- by the time I was finishing up my IC setup I did acually wish I would have built a liquid to air setup, it just would have been more fabrication, time and money.
Not stoping till 300 WHP
Heavensheros
« Reply #78 on: July 01, 2010, 05:19:00 PM »
i see i might look into getting a liquid/air intercooler later on down the road but as of right now after seeing your car im trying to find a place to make an exhaust manifold because yours is just sick ... i would wrap mine in exaust wrap along with the turbo exhaust side and downpipe to keep the heat where it should be.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #79 on: July 02, 2010, 04:33:00 AM »
I know the liquid/air IC's are great for compact space but they require their own coolant system pumps reservoir, radiator etc. to keep them cool enough. I'm not sure if a system like that is good for a street car? IDK enough about these systems.
But yeah, looking good, twin scroll manifold? Nice. Whatcha doing for engine management?
Heavensheros
« Reply #80 on: July 02, 2010, 04:45:00 AM »
what is twin scroll ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #81 on: July 02, 2010, 04:53:00 AM »
-__-
Google it...
twin scroll = divided turbine inlets
uses two inlets into the turbine housing. this way you can build a manifold to divert the exhaust pulses more evenly supposed to be good for faster spool and more overall power. usually expensive turbos and custom manifolds though, and makes running external wastegates really tricky
Heavensheros
« Reply #82 on: July 02, 2010, 05:00:00 AM »
ohh ok thank you !!!
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
coco-customs
« Reply #83 on: July 02, 2010, 05:51:00 AM »
Yep twin scroll!! Im interested to see how good she spools. Well for this summer im just gonna keep boost as low as I have to to run good AFR's with your chip but im woking on finding a cheap miata so I can run the harness out of it and run a AEM standalone EMS. My next investment aside form the body work will be the Mfactory LSD.
« Reply #84 on: July 02, 2010, 06:22:00 PM »
Still bent on that Miata thing eh? You could buy just a Miata harness and sensors if you wanted, but as much wiring as you'd save on the ECU install, you will need to do just as much to mesh the Miata harness with the Capri cabin harness. If you need a hand with standalones we can help!
coco-customs
« Reply #85 on: August 11, 2010, 03:39:00 PM »
Well after about 10 months is siting in a garage I finally was able to hit the key.…… and it fired right up!!!! I only drove it a few miles but everything seems to be just right. I dident install the wideband yet and I dident have a MBC on the turbo so I only hit 5 psi just to be safe. I'll have a better update and plenty o pics in the next few days. So excited!!!
« Reply #86 on: August 11, 2010, 03:42:00 PM »
Need pics and vids and full spec of what you've got done now!
Heavensheros
« Reply #87 on: August 11, 2010, 04:06:00 PM »
would like to drive to your area to see it in person if you dont mind ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
coco-customs
« Reply #88 on: August 11, 2010, 05:08:00 PM »
I wouldent mind one bit!! I would love the check out your car as well. You should try to make it up here some time this weekend, I'll have the wideband all installed by then and mabie a few minor bugs worked out also but after the weekend the motor/trans will be coming back out for some wire tucking action. Matt, pics videos and more info are all on the way!! I haven't had a single day off work since memorial day!! I'm just waiting for my sesional part time job to rap up in the next month or so and I'll be hard at work to really rap this car up. But for now the open 3 inch stainless downpipe sure does sound mean
« Reply #89 on: August 11, 2010, 05:35:00 PM »
Think you'll be able to make it to my meet for a debut????
