Author Topic: Transmissions...  (Read 5800 times)
SleeperTec
Transmissions...
« on: November 19, 2005, 04:31:00 AM »
Wondering what tranny's will cross into the Capri XR2.. I know that there are diff trannys that will bolt onto the B6T bell housing but mounts are different.. Now I need to know what trannys will fit and bolt right up to the Capri chassis.. Need info ASAP!
 THANKS!!.. Joe
need4speed428
Transmissions...
« Reply #1 on: November 22, 2005, 05:31:00 PM »
I think one from a fwd 323 gt from the late 80's will work but i'm not positive. Try www.mazda323performance.com and go to their forums. They should be able to tell you.
2007 Toyota Tacoma 4x4
1966 F100
need4speed428
Transmissions...
« Reply #2 on: November 26, 2005, 03:51:00 PM »
You know reich racing had a FWD tranny listed on their website a little while ago for $45 see if its still there. I'm sure they could tell you for sure if it would work or not. It was used and would probably cost quite a bit to ship it from canada but hey if you need one you need one right.
1966 F100
zxtunerdotcom
Transmissions...
« Reply #3 on: March 23, 2006, 05:36:00 PM »
91-96 1.8 powered 91-96 escort gt trans can work, except you'll need to get a n/a capri clutch master cyl and pedal assy, and the escort gt slave cyl assy to male it work. the shifter, bellhousing and other mount locations are all the same.
need4speed428
Transmissions...
« Reply #4 on: March 24, 2006, 05:29:00 PM »
Hey you wouldn't happen to know how much power that tranny can take do you? If it can take more than the pathetic tranny thats in it I might consider doing that. Also do you know what the final drive gear is?
1966 F100
zxtunerdotcom
Transmissions...
« Reply #5 on: March 24, 2006, 09:42:00 PM »
Quote
it's a g series trans like what the turbo capri originally came with. i understand the g series tranny can take about 300hp and after that wierd failures can occur like output shaft bearing races spinning in the case.
the real trick to tranny longevity is driving style and correct clutch adjustment. the 2 spider diff is not happy with violent wheel hop from a hard launch, and the synchros and shift linkage aren't going to live long w/ speed shifts or gear banging.
if you have someone who can mix/match parts, here is your dream tranny: Mazdaspeed Protege. It has a LSD and dual cone synchros inside it. i believe it will bolt up to the B6 motor, with install issues centering around adding a hydraulic clutch setup and having custom axles made to accept the 28 spline diff side gears.
rob
JJ
Transmissions...
« Reply #6 on: March 25, 2006, 03:23:00 AM »
i'd like to see someone swap out the 5th gear for something that lowers the rpms a bit at 65-70mph...
4th gear pretty useless anyways, so it wouldn't hurt the car too bad i think. I'd think we could squeeze 2-4 mpg out of that for highway driving...?
JJ
Transmissions...
« Reply #7 on: March 25, 2006, 06:41:00 AM »
Theres a writeup for the 323 GT for a 5th gear swap.  The swapped gear comes from a Mazda 626 5spd, not sure what years though. It drops 5th gear RPM's by 500 lower than normal.
zxtunerdotcom
Transmissions...
« Reply #8 on: March 25, 2006, 03:39:00 PM »
theres a 0.696:1 5th gear ratio that fits the turbo capri trans and is available thru ford - the part numbers are  F32Z-7K316-B and F8CZ-7144-BB. The locknuts part numbers are F5CZ-7N170-AA and 1L2Z-7N170-AA.
expect to pay around $180-200 for the parts.
rob
Transmissions...
« Reply #9 on: March 25, 2006, 04:25:00 PM »
Heres the link to the writeup for it, i'd rathe get a junkyard gear than a fomoco part that costs $180 but thats just me.
http://rxtrme7.aaph.com/gtx/gears.html
zxtunerdotcom
Transmissions...
« Reply #10 on: March 27, 2006, 06:56:00 PM »
quick reference:
the 626 gear set is .717:1 and the ford escort part is .696:1.
rob
Transmissions...
« Reply #11 on: March 28, 2006, 04:24:00 PM »
Whats the stock XR2 5th gear ratio?
zxtunerdotcom
Transmissions...
« Reply #12 on: April 20, 2006, 08:35:00 PM »
0.795:1
here's Capri tranny gear ratios and speed at 3000 rpm (assuming 195-50-15 tires):
N/A trans (rounded):
1st - 3.42 - 14mph
2nd - 1.85 - 26mph
3rd - 1.29 - 38mph
4th - 1.03 - 47mph
5th - 0.82 - 60mph
reverse - 3.21 - 15mph
final - 4.11
turbo trans (rounded):
1st - 3.31 - 16mph
2nd - 1.83 - 28mph
3rd - 1.23 - 42mph
4th - 0.97 - 54mph
5th - 0.80 - 66mph
rev - 3.17 - 16mph
final - 3.85
of you changes the 0.795 to a 0.696 5th gear, 3000rpm would be changed to 75mph, and the 626's .717 would be 73mph.
afaik total choices for 5th gear in a capri turbo trans range from 0.88 to 0.70, and final drives from 3.45 to 4.59 (some will need custom axles)
rob
 [ April 21, 2006, 02:49 AM: Message edited by: zxtunerdotcom ]
Transmissions...
« Reply #13 on: September 27, 2009, 05:32:00 PM »
hey rob, you may know this, will the tranny from a SVT FOCUS mate to the b6 bellhousing? cuase i know the ZETEC used in the zx2 has a g series right? and the focus should be the same...
and that tranny is a GETRAG 6 speed, right?
just need the goods to set up the hydraulic clutch....Joe...RCICustoms...
P.S. this is joe in kentucky. we had a red zx2 with the combat bomb body kit.. with a gude turbo beater head package. we bought all kinds of goodies for that car, and for the capri i currently have, from you.. i actually bought the goodridge stainless lines and brake rotors and well all kinds of shit, in late 2007 for our capri.... you gotta remember someone whos spent as much as we have with ya over the past 4 years or so...LOL
