Author Topic: Boost Controller  (Read 5513 times)
Heavensheros
Boost Controller
« on: February 10, 2008, 07:01:00 AM »
So im getting a boost controller in a couple of days ordered it on ebay from 2nerfix so imm excited for that and in a couple days will be ordering the strut bar , after that the ECU pretty excited for that
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
1992xr2
Boost Controller
« Reply #1 on: February 10, 2008, 09:08:00 AM »
Awesome, getting boxes is always the most exciting feeling after test driving with the new parts then pausing and thinking, "holy shit, that was fast."  Whose ecu are you going to get?
\\\'90 Civic Si
Boost in the near future.
Boost Controller
« Reply #2 on: February 10, 2008, 09:58:00 AM »
Hey XR2!  Come on,Who's do you think?  Gus.
pmpsht
    • http://www.TunerFixx.com
Boost Controller
« Reply #3 on: February 10, 2008, 10:13:00 AM »
Hey Joshua, thanks for the order, it's going out first thing this next week.  Enjoy!
Cory Barry
1992xr2
Boost Controller
« Reply #4 on: February 10, 2008, 10:56:00 AM »
Well naturally, I know who's I'd buy if I wasn't going MS but you enver know what silly decision oter might make.
\\\'90 Civic Si
Heavensheros
Boost Controller
« Reply #5 on: February 11, 2008, 11:56:00 AM »
what do you think the boost controller will be in  ??  imm really excited and once the weather warms up to about 30 not this 4 and 5 we have i will be fixing the wastegate and imm buying rocketmans ECU
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
Boost Controller
« Reply #6 on: February 14, 2008, 04:36:00 PM »
Ok so i got the boost controller and its installed was very easy but now i am wondering how do you adjust this thing ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Boost Controller
« Reply #7 on: February 14, 2008, 06:23:00 PM »
set the dial to 'warp drive'
pmpsht
Boost Controller
« Reply #8 on: February 15, 2008, 02:32:00 AM »
To decrease boost turn knob Counter Clock Wise (loosen=less).
You will want to start low and increase 1.5 turns at a time.  That's about 1 lb of boost at a time.  Make sure you tighten down that lock nut with a wrench once you have it set at your desired boost so it doesn't vibrate lose.
Cory Barry
Heavensheros
Boost Controller
« Reply #9 on: February 15, 2008, 10:55:00 AM »
thanks for the help i got it all installed kind of hard the tubes were a tight fit and i had to put the tubes in the engin bay and run car for 30 minutes to heat it all up so it would fit but its all on now i need to fix wastegate so i have an accurate boost level to adjust with thats getting done sunday so very excited
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Boost Controller
« Reply #10 on: February 15, 2008, 02:58:00 PM »
Hey Josh! You'll want to disconnect the "overboost" plug at the firewall. And don't set over 10lbs until You get Rocketman's ECU in place. You'll have some fun at 10lbs still.  Good Luck Gus.
Heavensheros
Boost Controller
« Reply #11 on: February 15, 2008, 03:17:00 PM »
thanks and sunday i get wastegate fixed to stop "boost creep"
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
pmpsht
Boost Controller
« Reply #12 on: February 28, 2008, 04:13:00 AM »
Joshua, you get everything installed and working?
Cory Barry
Yuri
Boost Controller
« Reply #13 on: March 25, 2008, 10:56:00 AM »
instead of starting a new thread i thought id just put this here it is relevant to the thread
i had to go in for emission tests today(grr) she passed just fine but just in case i turned the boost down to stock 6psi. holy Christ the car was slow. now she's back to the 16-18 range... much nicer
moral of the story:
BUY A ROCKETCHIP AND A BOOST CONTROLLER
1992xr2
Boost Controller
« Reply #14 on: March 25, 2008, 01:48:00 PM »
lol, I never really realized how much turbos are important to having fun in a Capri, try not boosting for weeks on end waiting for money for a new turbo  :(   The next time I hit boost I was like oo
......0
\\\'90 Civic Si
