Author Topic: DOOR SPEAKERS AND HEADLIGHT MOTOR  (Read 6074 times)
gadawgs34
« on: February 16, 2010, 03:51:00 AM »
I have a 1991 Capri just got it and love it. So i was hoping that someone could tell me is it hard to replace a headlight motor? Also Im going to replace my door speakers any tricks or anything I need to know before doing the job?
Mike Robinson
drbob
« Reply #1 on: February 16, 2010, 05:59:00 AM »
As for the door speakers, they are a very shallow depth speaker.  Measure inside clearence first, or you will be sorry.  This is the voice of experience.
AUSTRALIAN Shepherd
Surfnut
« Reply #2 on: February 16, 2010, 06:07:00 AM »
Mike,
Are you planning on replacing the entire headlight door, mechanism and motor or just the motor itself ?
Dave
gadawgs34
« Reply #3 on: February 16, 2010, 06:49:00 AM »
Just the motor itself Dave
Thanks Mike  :cool:
Mike Robinson
Surfnut
« Reply #4 on: February 16, 2010, 07:38:00 AM »
In that case, I'm sorry but I can't help you much.  I haven't removed one of the motors in a couple of years and I don't remember much about it.
I had posted here on Teamcapri about having one headlight making me nuts and I received a lot of help from other members with that problem.  I did a search for that post but it seems to have disappeared from the archives.
If I remember correctly, turn the headlight to the "up" position, take a few philips-head screws out of the black plastic that surrounds the headlight  and remove that black plastic.  Then there are 4 or 5 bolts (use a 10mm socket) and one wiring connector to remove the entire headlight assembly (including motor) from the car.  From there I don't think it's too much trouble to get the motor off but I'm sorry 'cause I can't remember all the details.
Good luck,
Dave
gadawgs34
« Reply #5 on: February 16, 2010, 07:47:00 AM »
Thank you Dave  ;)
Mike Robinson
Heavensheros
« Reply #6 on: February 16, 2010, 08:27:00 AM »
it is very easy there are 2 bolts on top and 2 on the back bottom and 2 plugs to take out the assembly and then there are some screws on the side of the assembly 4 for the top cover 4 for the black housing ... take that off and you will be able to see the motor and it is only a few screws to take off ... very simple i just looked at it and had it replaced in 20 minutes from just looking at it for the first time
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
gadawgs34
« Reply #7 on: February 16, 2010, 08:44:00 AM »
Thank you Joshua  :cool:
Mike Robinson
gadawgs34
« Reply #8 on: February 16, 2010, 08:46:00 AM »
I guess I should ask where do i goto to buy a headlight motor?
Mike Robinson
drbob
« Reply #9 on: February 16, 2010, 09:27:00 AM »
Now before you buy a motor, remember, it may be OK, it may just need cleaning.  I am sure there are a few people on this forum that were able to fix their headlight motor without replaceing it.  So folks, lets hear from you and give this guy some good advice.
AUSTRALIAN Shepherd
Heavensheros
« Reply #10 on: February 16, 2010, 09:45:00 AM »
i would try to clean the motor and the contacts and if not im pretty sure Russ has some lying around !
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
gadawgs34
« Reply #11 on: February 16, 2010, 09:54:00 AM »
Thanks guys I will try cleaning it first it moves but very slow. And something under the dash clicks when it is moving. Ill try tonight and let yall know the results of my work.    :D
Mike Robinson
gadawgs34
« Reply #12 on: February 16, 2010, 01:56:00 PM »
Hi again guys. Got out the motor it is trash bushings and contacts all but gone. Gonna go hunting a motor now. Thanks for all the help.   :cool:
Mike Robinson
« Reply #13 on: February 16, 2010, 02:09:00 PM »
i cant remember what side motor i have, but i believe that they are interchangable by swapping the arm on them....
i put 7in oversized kenwood mid/tweet separates in mine just fine
« Reply #14 on: February 16, 2010, 02:16:00 PM »
The headlight motors are interchangeable.  Gostlrs is a good guy to work with, and if a deal with him falls through, I have extras, as well!
