Author Topic: Security Fuel Pump Cutoff  (Read 5064 times)
kellsonm
    • 1994 Mercury Capri
« on: August 02, 2015, 11:47:10 PM »
Hey has anyone put a fuel pump cutoff in their capri? Perhaps the stock ford cutoff can be used/modified?
Anyway, I'd like to have a hidden cutoff switch since the car is parked ok the street usually.
Re: Security Fuel Pump Cutoff
« Reply #1 on: August 03, 2015, 09:16:11 PM »
You could switch the fuel pump, ignition, ECM, power relay to name a few. Hidden under the dash would be most convenient. Many will go for the stereo rather than the whole car. That's where a detachable face plate comes in handy. I would opt for a noisy security system over just disabling it. Thank God I live in an area where you can still leave your keys in your car.
« Reply #2 on: August 05, 2015, 04:22:11 PM »
My red XR2 had a 'security switch' in it, that a previous owner installed and I was totally unaware of.
They hid a piece of speaker wire with a switch under the dash. It was wired in series with the ignition coil.
When getting the car running/roadworthy, I thought it was extra un-needed wire, and removed it. I spent ~3 days troubleshooting trying to get the car to start again. I nearly replaced the engine harness. I noticed it at the last second, it was tucked under the fuse box in the engine bay.
This system would have provided a lot of voltage drop to the coil, reducing spark energy. Would not recommend. Extra headaches if you forget about it, or someone else is trying to work on your car.
« Reply #3 on: August 06, 2015, 06:31:38 PM »
You could install a switch that feeds the ground to the fuel pump rely. This would probably be one of the cheapest, easiest, and safest methods to installing an “anti-theft  switch” .
All you have to do is cut the original ground wire off the fuel pump’s relay that’s located by the ecm. Then connect a single wire to the relay's black wire and run it to your switch and ground the other contact of the switch anywhere nearby.
I do agree with Mitch, theives will steel the stereo and not the entire car.
kellsonm
« Reply #4 on: August 06, 2015, 11:03:21 PM »
Hmm thanks for all the info! I was thinking of going the fuel pump relay route. Although, is there a dedicated fuse for the fuel pump? If I were to park the car for a long period of time, I could always just pull the fuse. I would imagine any thief would just think it's an old broken car.
« Reply #5 on: August 07, 2015, 09:41:17 AM »
There is no dedicated fuse for the fuel pump.
« Reply #6 on: August 07, 2015, 04:28:14 PM »
I'd thought about putting an extra ignition coil under the seat, with the hot end going under the fabric. If a thief or 'friend' tries to start your car without disabling the correct switches on/under the dash, they'll get a nasty shock in the ass! hah.
cjizzle252
« Reply #7 on: August 07, 2015, 08:48:25 PM »
i installed a walbro 255 fuel pump and rewired it directly to my battery with a toggle switch, thicker gauge wire helps you get max power to the pump as well
« Reply #8 on: August 07, 2015, 09:29:08 PM »
Did you wire in a fuse? why not use the stock wiring to trigger a relay? A simple toggle switch really isn't safe
kellsonm
« Reply #9 on: August 14, 2015, 12:05:05 AM »
Oh yeah why don't I just put an inline fuse in one of the wires?
